0 Replies Latest reply on Aug 24, 2007 7:25 AM by BMBug
    Center with stage child swf
    BMBug
      hello
      I create a swf that call another swf, i use addchildAt after the preload. The first swf is center using the size of the stage, but i can do the same to the second swf. give me a error "
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at swf2_fla::MainTimeline/swf2_fla::frame1()"
      I have the flas here: http://www.digisource.pt/test/flas.zip
      swf1.test
      I creat a mc call cub1
      PHP Code:
      import flash.display.Loader;
      import flash.display.LoaderInfo;
      import flash.net.URLRequest;
      import flash.events.Event;
      import flash.events.ProgressEvent;
      import flash.display.MovieClip;
      import flash.display.StageAlign;
      import flash.display.StageScaleMode;
      stage.align=StageAlign.TOP_LEFT;
      stage.scaleMode=StageScaleMode.NO_SCALE;
      stage.addEventListener(Event.RESIZE, resizeHandler);
      addEventListener(Event.ENTER_FRAME, resizeHandler);
      var aCarregar:Loader = new Loader();
      carregarSwf("swf2");
      function resizeHandler(event:Event):void {
      cub1.x = (stage.stageWidth/2);
      function carregarSwf(teste:String) {
      var swfACarregar:String=teste;
      var swfQueCarrega:URLRequest = new URLRequest(swfACarregar+".swf");
      aCarregar.load(swfQueCarrega);
      aCarregar.contentLoaderInfo.addEventListener(Event.OPEN,showPreloader);
      aCarregar.contentLoaderInfo.addEventListener(ProgressEvent.PROGRESS,showProgress);
      function showPreloader(evt:Event):void {
      //code to control preload
      function showProgress(evt:ProgressEvent):void {
      //math of the preload bar
      function showLoadResult(evt:Event):void {
      addChildAt(aCarregar,0);
      in swf2.fla - i creat mc call cub2
      cub2.x = (stage.stageWidth/2);
      Please help me understand the problem
