2 Replies Latest reply on Sep 12, 2007 5:55 AM by Robert_Csiki
    DTD for data-management-config.xml
    Robert_Csiki Level 1
      Is the data-management-config.xml file structure somewhere explained? I wonder why isn't this file (as well as all the other FDS config files) validated against a DTD or XML schema?
      I'm trying to configure multiple parameters for a destination server method, without success so far. The following attempts have all failed
      <server>
      <fill-method>
      <name>getFolderContent</name>
      <params>java.lang.String;boolean</params>
      </fill-method>
      </server>
      <server>
      <fill-method>
      <params>java.lang.String, boolean</params>
      </fill-method>
      </server>
      <server>
      <fill-method>
      <params>java.lang.String</params>
      <params>boolean</params>
      </fill-method>
      </server>
      I want to pass in a Java String and a boolean (the primitive). What's the correct syntax? Thank you.
