5 Replies Latest reply on Mar 18, 2010 12:57 PM by LouisaBoyles
    IE problems
    LouisaBoyles
      Hi there,
      I am having problems with my top navigation bar in IE 7 & under (8 seems to be fine), where the last link "press" has dropped to the next line under "home".
      And in IE 6 & under my sidebar nav has moved over to the right.
      I am new to this so I have been trying to work out what bugs have been causing this so I can apply Conditional comments.
      Could the side bar nav issue be the double float margin bug? I am still trying to work out what bug relates to the top nav.
      Does anyone know?
      http://www.denotestationery.com/denote_localroot1/denotehome.html
      Thanks in advance
        • 1. Re: IE problems
          LouisaBoyles Level 1
          Update: I have applied display:inline; to my sidebar div, which seems to have solved the extra margin problem. Still not sure what to do about the topnav though
          • 2. Re: IE problems
            polar_bare Level 4
            UPDATED:
            Try this in your CSS, you need to expand the div to 675px;
            #topnavcontainer {
            BACKGROUND-IMAGE: url(navlines.png);
            MARGIN-TOP: 35px;
            WIDTH:675px;
            DISPLAY: inline;
            BACKGROUND-REPEAT: repeat-x;
            FLOAT: right;
            HEIGHT: 34px;
            MARGIN-RIGHT: 30px
            Jim
            Your width of your #topnavcontainer is too narrow also. If you increase the size to 675px, it displays correctly if  you put  your float back in.
            • 3. Re: IE problems
              osgood_ Level 8
              LouisaBoyles wrote:
              Hi there,
              Add margin: 0; to your .topnav ul just before margin-top: 9px; (as shown below). Incidentally you dont require font-family: none; and text-decoration: none; should be set on the 'a' (anchor) tag.
              .topnav ul {
                  font-size: 12px;
                  color: #333333;
                  list-style-type: none;
                  font-family: none;
                  margin: 0;
                  margin-top:9px;
                  padding-left: 16px;
                  padding-right: 16px;
              • 4. Re: IE problems
                polar_bare Level 4
                Yes, Os, that worked good job.
                Jim
                • 5. Re: IE problems
                  Thanks very much OS & Jim for your help.
                  I used OS tactic and it worked!
                  May I ask.... Was this a a problem with my CSS rather than IE bugs, or both? I would like to know what the problem was & why I added margin: 0 to the CSS & what that does so I am able to prevent future mishaps.
                  Forgive me if I should know!
