3 Replies Latest reply on Sep 12, 2007 6:52 PM by insane123
    hilite field line
      Im trying to hilite the mouseline of a field on mouseup, but the result returned is -1, indicating the mouse is not over a field, but it is. Then it hilites every line in the field.
      Im using the same script as for other hiliting of lines in fields, which works, so I don't know why its not working.
      Any ideas? Thanks.
        • 1. Re: hilite field line
          Angular Dashpot
          Make sure you substract the top of the fieldsprite when you use locVToLinePos
          • 2. Re: hilite field line
            Chunick Level 3
            Attach this code to your field member sprite as a behavior:
            property mem
            on beginSprite me
            mem = sprite(me.spriteNum).member
            on mouseUp me
            ln = the mouseLine
            I've tested it on the sprite of a field member, so if it doesn't work for you then you might be using a flashComponent or text member.
            • 3. Re: hilite field line
              insane123 Level 1
              Thanks, but it did the same thing. Im not using a flash component and it is a field not text. Im not sure what else to try.
              Also, another problem... when using 'set the top if sprite' on a field, it moves the whole field on the stage, keeping the field the same size instead of just increasing the top of the field. What am I doing wrong?
