2 Replies Latest reply on Mar 18, 2010 12:43 PM by the_wine_snob
    Preferences
    lawoks
      Have Premiere Pro CS4
      Preferences:
      Edit/Preferences/General
            Still Image Default Duratrion
                  1 Frame
                  1,000,000 Frames
      No matter what I type, the program will OK this.  The result are the same.  (I think it is the default)
      What is wrong?
      Thank you.
        • 1. Re: Preferences
          shooternz Level 6
          I am only guessing what your problem is!
          You must change the Duration Preference before you place the items in the timeline.
          Actually...I think you need to do it before you import the items into the Project Bin ( maybe someonewill correct this)
          • 2. Re: Preferences
            the_wine_snob Level 9
            Craig,
            You are correct, with one addition - as of CS4.2, one can now Select multiple stills in the Project Panel, Rt-click and then alter the Duration. From CS3 and earlier, one had to Delete and re-Import for the Preferences to take affect.
            Hope that this helps,
