3 Replies Latest reply on Mar 22, 2010 4:22 PM by FTQuest
    Playing a Live Audio Stream: Memory leak issue, how to limit the buffer size ?
    POUSSIN Mathieu Level 1
      Hello,
      I have a little problem, I've made a simple media player (Flex/AIR powered, but the question isn't specific to AIR) to read a live stream that come from IceCast,
      The problem is, the memory usage grow grow grow grow too much (It never stop to grow...), any Idea of how can I stop this ? Can I limit the buffer size ?
      Here are some part of the code :
      [Bindable] public var loadedUrl:URLRequest;
      [Bindable] public var channel:SoundChannel;
      [Bindable] public var song:SoundAsset;
      [Bindable] public var songStatus:String = "";
      [Bindable] public var songTitle:String = "";
      [Bindable] public var songAlbum:String = "";
      [Bindable] public var songArtist:String = "";
      [Bindable] public var songPos:Number = 0;
      /** Function that load an URL for remote resource loading, then redirect to fileSelected */
      private function loadUrl():void {
      loadedUrl = new URLRequest(mediaUrlInput.text);
      fileSelected();
      /** Generic function called when loading a local or remote file, perform ID3 loading */
      private function fileSelected():void {
      if(songStatus=="Playing") {
      channel.stop();
      songStatus="Stopped";
      songPos = 0;
      song = new SoundAsset()
      song.addEventListener(Event.ID3, infoLoaded);
      song.load(loadedUrl);
      /** Play function of the player, activate the channel and initialize and bind a sound transformer */
      private function play():void {
      songStatus="Playing";
      channel = song.play(songPos);
      bindVolume();
      var songTransform:SoundTransform = new SoundTransform(volumeSlider.value);
      channel.soundTransform = songTransform;
      /** Pause function of the player, save the position in songPos then stop the channel */
      private function pause():void {
      songPos = channel.position;
      songStatus="Paused";
      channel.stop();
      /** Stop function of the player, stop the channel and set songPos to 0 */
      private function stop():void {
      if(songStatus!="Stopped") {
      channel.stop();
      songPos = 0
      (I removed the useless lines (ID3 loading, volume slider binding, etc) on this paste.
      Any idea of how can I fix it ?
      Thank you !
