0 Replies Latest reply on Mar 18, 2010 4:03 PM by Jason Szeto
    [svn:fx-trunk] 14866: Merging revision 14865 from 4.x to trunk
    Jason Szeto Level 3
      Revision: 14866
      Revision: 14866
      Author:   jszeto@adobe.com
      Date:     2010-03-18 16:03:07 -0700 (Thu, 18 Mar 2010)
      Log Message:
      Concatenated matrix ApplicationDomain bug fix
      http://bugs.adobe.com/jira/browse/SDK-25752 - Marshall Plan Rendering Error in Flex 4 when using Flex 3 containers
      MatrixUtils.getConcatenatedMatrix wasn't properly traversing the parent chain when that chain spanned sibling ApplicationDomains. The solution is to figure out when we have crossed the ApplicationDomain dividing line and ask the new ApplicationDomain for its class definition of UIComponent. The code has been optimized to reduce the number of getDefinition function calls.
      I refactored getConcatenatedMatrix and getConcatenatedComputedMatrix into a helper function.
      QE notes: Needs full mustella run
      Doc notes: none
      Bugs: SDK-25752
      Reviewer: Darrell
      Tests run: checkintests, DropDownList, ComboBox, PopUpAnchor
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
      Property Changed:
          flex/sdk/trunk/
