0 Replies Latest reply on Mar 18, 2010 7:24 PM by Carol L. Frampton
    [svn:fx-trunk] 14869: Merge mirroring changes 14728-14730, 14772-14775, 14806 from 4.x to trunk.
    Carol L. Frampton
      Revision: 14869
      Revision: 14869
      Author:   cframpto@adobe.com
      Date:     2010-03-18 19:24:27 -0700 (Thu, 18 Mar 2010)
      Log Message:
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/WindowedApplication.as
          flex/sdk/trunk/frameworks/projects/airspark/src/spark/components/WindowedApplication.as
          flex/sdk/trunk/frameworks/projects/flash-integration/src/mx/flash/UIMovieClip.as
          flex/sdk/trunk/frameworks/projects/framework/defaults.css
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/HScrollBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Menu.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridHead er.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/UIFTETextField.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/HSlider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VSlider.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/CheckBoxSkin.mxml
      Property Changed:
          flex/sdk/trunk/
