6 Replies Latest reply on Mar 24, 2010 1:53 PM by ghalex
    Rectangle
    hidarikani Level 2
      I want to create a custom UI component that:
      1. looks like a rectangle (has a border, a fill and I can change it's dimensions)
      2. behaves like a UI component (I can add it to a HBox container in MXML, it dispatches mouseOver, mouseOut event)
      Where should I start? Which class should my custom component inherit from?
        • 1. Re: Rectangle
          ghalex Level 1
          Try this:
          public class RectangleShape extends Canvas
          public function RectangleShape( x:Number=0, y:Number=0, w:Number=144,
          h:Number=108 )
          super();
          this.x = x;
          this.y = y;
          this.width = w;
          this.height = h;
          public function draw() : void
          graphics.clear();
          graphics.lineStyle( 1 )
          graphics.beginFill( 0x000000,  1);
          graphics.drawRect(0, 0, width, height);
          graphics.endFill();
          override protected function updateDisplayList(w:Number, h:Number) : void
          super.updateDisplayList(w,h);
          draw();
          • 2. Re: Rectangle
            Flex harUI Adobe Employee
            UIComponent
            • 3. Re: Rectangle
              That will work but is very heavy if you are going to have a lot of them.
              Starting from UIComponent will be much more lightweight but a bit more work.
              See the custom components chapter in the doc.
              • 4. Re: Rectangle
                ghalex Level 1
                Using Canvas instead of UIComponent will help you if you want to develop
                more shapes later for example if you want to use composite pattern and make
                a GroupShape that contains 3 basic shapes, Canvas will auto resize his width
                and height
                but UIComponent will not do that.
                • 5. Re: Rectangle
                  hidarikani Level 2
                  Although I've overridden the measure method:
                  override protected function measure():void {
                      super.measure();
                      measuredMinWidth = 18;
                      measuredMinHeight = 18;
                  unscaledWidth and unscaledHeight are equal to 0 so the rectangle isn't visible
                  override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void {
                       trace(unscaledWidth); //0
                       trace(unscaledHeight); //0
                       super.updateDisplayList(unscaledWidth, unscaledHeight);
                       graphics.beginFill(0x000000, 1);
                       graphics.drawRect(0, 0, unscaledWidth, unscaledHeight);
                  I don't understand how the unscaledWidth and unscaledHeight are determined. Do I have to add code to the parent that computes unscaledWidth and unscaledHeight?
                  • 6. Re: Rectangle
                    ghalex Level 1
                    reprezents the min size you must set width and height to have something in
