3 Replies Latest reply on Mar 19, 2010 11:00 AM by DigitalArchitectCanada
    Drag and Drop hitTest, Dressing a Model Game.
    BigdaddyVELTRI
      I need to create a game where you drag and drop clothing onto a body that snaps into place then when the body is fully clothed you click a button to see if the clothing you selected is correct. There will be 4 different areas of clothing with 3 options for each area, one for each area is correct. Does anyone have any advice on how to achieve this? In either actionScript 2 or 3.
        • 1. Re: Drag and Drop hitTest, Dressing a Model Game.
          DigitalArchitectCanada Level 3
          Yeah just create a movieclip that has a sqare in it say 30 X 30 and place multiple instances of them wherever you need clothes to "snap" onto the body. Then as you drag clothes around on the stage you can just run a hit test against these "nodes" and snap the clothes onto their position. Just make the nodes have an alpha of 0.  This should get you started.
          Create a basic pants graphic, put it on the stage and give it an instance name of pants.
          Draw a square and turn it into a movieclip. Give it an instance name of pantsNode.
          On the timeline for this frame (or if you're experience enough, in your document class) put this code:
          var currentClothing:MovieClip;
          pants.addEventListener(MouseEvent.MOUSE_DOWN, beginDragClothing);
          pants.addEventListener(MouseEvent.MOUSE_UP, endDragClothing);
          pants.targetNode = pantsNode;
          pants.nodeBounds = new Rectangle(pantsNode.x, pantsNode.y, pantsNode.width, pantsNode.height);
          function beginDragClothing(e:MouseEvent):void
              currentClothing = e.currentTarget as MovieClip;
              stage.addEventListener(MouseEvent.MOUSE_MOVE, dragClothing);
              currentClothing.startDrag();
          function dragClothing(e:MouseEvent):void
              if(currentClothing.hitTestObject(currentClothing.targetNode) && mouseX > currentClothing.nodeBounds.left && mouseX < currentClothing.nodeBounds.right && mouseY > currentClothing.nodeBounds.top && mouseY < currentClothing.nodeBounds.bottom){
                  //The currentTarget has hit it's acceptable node
                  currentClothing.x = currentClothing.targetNode.x;
                  currentClothing.y = currentClothing.targetNode.y;
                  currentClothing.stopDrag();
                  stage.removeEventListener(MouseEvent.MOUSE_MOVE, dragClothing);
              e.updateAfterEvent();
          function endDragClothing(e:MouseEvent):void
          You should be able to easily adapt that to whatever you want to do. Hope that helps and if it does please kindly mark the question as answered. Thanks,
          Jesse
          • 2. Re: Drag and Drop hitTest, Dressing a Model Game.
            BigdaddyVELTRI Level 1
            Thanks Jesse, This works really well for snapping the movieclips into postion. If the pants are snapped into postion, Is there a way to have the movieclip "pants" go back to its default position if another pair of pants is clicked on?
            • 3. Re: Drag and Drop hitTest, Dressing a Model Game.
              This should do it (untested though!)
              Not the greatest code on earth but it will get the job done.
              pantsNode.currentClothing = undefined;
                     //Check and see if something has been applied to the target node already. For example pantsNode.currentClothingObject
                    if(currentTarget.targetNode.currentClothingObject != undefined){
                      //There is already clothing on this node. Send that clothing somewhere else
                      currentTarget.targetNode.currentClothingObject.x = 0;
                      currentTarget.targetNode.currentClothingObject.y = 0;
                    currentTarget.targetNode.currentClothingObject = currentClothing;
