0 Replies Latest reply on Mar 19, 2010 6:35 AM by Mete Atamel
    [svn:fx-trunk] 14878: Bug: BLZ-501 - Login-after-disconnect flag does not work after session timeout
    Mete Atamel Level 1
      Revision: 14878
      Revision: 14878
      Author:   matamel@adobe.com
      Date:     2010-03-19 06:34:54 -0700 (Fri, 19 Mar 2010)
      Log Message:
      QA: Yes
      Doc: No
      Details: MessageAgent#reAuthorize method was calling MessageAgent#disconnect method with the assumption that this fully disconnected the Channel and internalSend triggers a reauthentication (login) with Channel#interalConnect and cached credentials. This was a wrong assumption in cases where multiple MessageAgents use the Channel. Now, instead, ChannelSet#disconnectAll is called to make sure Channel is fully disconnected which in turn makes sure Channel#internalConnect is called with cached credentials.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/BLZ-501
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/MessageAgent.as
