1 Reply Latest reply on Mar 20, 2010 12:57 AM by Radhakrishna Bhat
    Connecting to a webservice which is on a different port then the wsdl
    Kauff2
      I was wondering if it is possible in Flash builder 4 to use a webservice on Port B when the WSDL is hosted on Port A.  I understand that this sounds really silly and it is.  The problem is I need to connect to existing software that can not be modified.  I was able to do this in Flex 3 with some modification to the generated code but I cant seem to do the same thing in Flash builders 4 generated code.
      Sample WSDL url http://server:8080/wsdl/Sample.wsdl
      Sample SOAP url http://server:93/SomeApp.exe/Sample.ASP
      Any advice, I see that there is a soap port property but I havent found much information as to what its value is and how to change it or how to change the port that the webservice call goes out on.
