2 Replies Latest reply on Mar 21, 2010 2:25 PM by soom1976
    Nested sequence duration changed problem
    soom1976 Level 1
      Premiere Pro 4.0.1
      I'll try to explain it as clear as possible:
      I have nested a sequence on a time line. Then I entered the nested sequence and edited it. It happened, that the duration of that nested sequence has changed - it became longer. Now I go back to the main Sequence time line and I want to extend the nested sequence so it matches the changed duration, but NO – it won't let me do it! I've tried to drag the same nested sequence from the project window – still same old (shorter) duration.
      What is wrong? Is that a bug? Is that a feature? Do I have to do it some weird way?
        • 1. Re: Nested sequence duration changed problem
          Harm Millaard Level 7
          First update to 4.2.1
          Then edit in the original sequences only. Changes will be reflected in the nested ones.
          • 2. Re: Nested sequence duration changed problem
            soom1976 Level 1
            Updated to 4.2.1
            Nothing changed
            It still remembers the duration of the sequence at the moment, when it was nested. If I edit the nested sequence and prolong it's duration, I cannot extend this sequence on the main time-line. I still can shorten it, but not to extend it. If I want to make the nested sequence longer, what I do is nest everything inside it again, then copy paste it to the original time-line – this is a bit awkward...
