1 Reply Latest reply on Mar 20, 2010 5:54 AM by Zabeth69
    Cmd Shift U stopped putting
    izycrzy
      I used to use this keywboard shortcut all the time to put files onto the server. Now it doesn't work anymore. Also if I go to the drop-down menu "Site" and select "Put" this doesn't work either. The only way I can put a file on the server is by using the file manager and dragging the file into the folder. Any ideas? Thanks!
        • 1. Re: Cmd Shift U stopped putting
          Zabeth69 Level 5
          Have you changed Dreamweaver versions? Have you checked your Preferences and Keyboard Shortcuts? Keyboard Shortcuts is also under Edit, and you can set up your key combinations there.
          Alternatively, have you cleaned your keyboard recently, or worn it out? No, probably not...
          Those wiser than I might suggest rebuilding your Dreamweaver Configuration file, and here's a Tech Note about that:
          http://kb2.adobe.com/cps/422/36bda422.html
          Actually, that sounds like your best bet...
          Beth
