6 Replies Latest reply on Mar 20, 2010 1:54 PM by Nancy OShea
    Name for FTP host
    wefollow Level 1
      I be able to login ftp.www.com, but having trouble to connect from Site Definition.
      I have FTP host for " public_html", could be i have wrong directory....?????
      thanks for reading...help
        • 1. Re: Name for FTP host
          J Cellini Level 3
          What kind of error are you getting?
          If you are not sure about the ftp host, the best thing to do is to call your hosting company to make sure you have the correct ftp address. If you do, you might try checking the Use Passive FTP check box.
          • 2. Re: Name for FTP host
            wefollow Level 1
            I be able to connected with Filezilla, but not from Dreamweaver.
            On filezilla showed the folder...Web.
            I did type Web or public_html  on FTP host address, getting " cannot make connection to host...
            thanks you for your time....still can't connect from DW
            ps. as you said i will ask them for FTP address and let you know
            • 3. Re: Name for FTP host
              J Cellini Level 3
              It sounds like your ftp login is correct. I have trouble with the DW ftp also. Sometimes it hangs trying to connect with the server. I use Filezilla a lot, but Dreamweaver is more convenient.
              Did you try passive ftp?
              Click on the Site menu and then Manage Sites. In the Manage Sites dialog box, make sure you site is highlighted if you have more than one site. Click the Edit button. On the Advanced tab, click the Test button. If it's not connecting, check the Use Passive FTP checkbox and click the Test button again. If it still isn't connecting, check the Use IPv6 transfer mode checkbox.
              If you are still not getting a connection, you might also try disabling your Firewall. Also try disabling your Anti-virus software to see if there might be a conflict. In fact, whenever I install new software, I disable my security software first.
              • 4. Re: Name for FTP host
                Mike_Watt Level 2
                If your website is http://www.mysite.com
                Then your FTP host (in DW) is simply: mysite.com
                EDIT 1: The reason being is that while your ftp address is likely ftp://www.mysite.com. DW only needs to know the mysite.com part... give that a shot.
                • 5. Re: Name for FTP host
                  wefollow Level 1
                  This site hosting with e-rice.net and FTP host address as WEB,  Host directory as mysite.com same Login and password.
                  but still having problem, i will contact with e-rice.net and ask for FTP HOST ADDRESS....THANKS
                  I will post after solved this problem...thanks for your time
                  • 6. Re: Name for FTP host
                    Not necessarily.  Hosting log-ins can vary quite a bit.
                    Some servers use numeric addresses: 123.456.789.101
                    While others may have named servers on the hosting company's domain: omega.webhost-company.com
                    Always check with the web host.
                    Nancy O.
                    Alt-Web Design & Publishing
                    Web | Graphics | Print | Media  Specialists
                    http://alt-web.com/
                    http://twitter.com/altweb
                    http://alt-web.blogspot.com
