1 Reply Latest reply on Mar 20, 2010 7:48 AM by FTQuest
    mapping image objects
    Saritha S
      hiii
      I have an image gallery application, i want to map some objects inside  each image,then mouseover it , a small popup of that object opens.,
      suppose if it is a picture of a big room, inside that so many items.say  sofa,char ,table,bed...etc....want to map each item and when we click on that, description window of that particular item opens as a small popup....
      Is there any way to do this  application....
      is there any way to do mapping or tagging an image  in flex..??any techniquess...??.
      does any body knows..please reply mee..
      Saritha
        • 1. Re: mapping image objects
          FTQuest Level 3
          I believe you posted this question before, and I gave you the working solution:
          draw empty graphic primitives - like rectangle - over particular area of your image. 'Empty' means that you don't specify fill or stroke; place this rect in a Group, give the Group an ID and that is it. You can listen to any mouse events when you hover or click this rect.
          FTQuest
