13 Replies Latest reply on Apr 29, 2013 4:13 PM by furziger
    XviD export crash (premiere and encoder)
    süsi Level 1
      i was finished editing a .flv file and then went File->Export->Media
      then changed all the resolution settings etc and saved the custom export preset... but i could only do it if i didn't press the XviD codec's properties...
      i could only select the xvid codec if i tired to select properties, i got an error message:
      """Sorry, a serious error has occured that requires Adobe Premiere to shut down. We will attempt to save your current project"""
      then it all crashed and the premiere error report came up...
      when i chose the xvid codec and pressed OK in the Export Settings page, then it went into the media encoder window, but when i pressed "start queue" in there, then it crashed again...
      does anyone know what's wrong with it??
      really hard to keep myself calm when seeing it happen :S:S:S piece of sh-t!!
      i'm using K-Lite mega codec pack (which has worked fine previously, even with windows 7..)
      also using JetAudio Plus VX media player, which has xvid built in imo. could that cause the problem??
      when i try to export a .mpg file after the crash, then i get the same crash again, but when i reset all the codec settings (in codec pack menu), then it shows up with a blank XviD status windows and everything just freezes...
      then the only option is to reinstall the codec pack i think... then i can atleast export the mpg files :s
