3 Replies Latest reply on Sep 6, 2007 4:46 AM by semx
    Need to loop an FLV
    semx
      Hi guys,
      I have a movie player that uses custom code instead of components and all is well. But now I need to loop the videos instead of just having them play through and stop. Does anyone have a block of code that will pull that off?
      My current code is attached.
      Thanks!
        • 1. Re: Need to loop an FLV
          chopTheWood Level 1
          Here's a bunch of custom video controller code. You can probably get something from it:
          var nc:NetConnection = new NetConnection();
          nc.connect(null);
          var ns:NetStream = new NetStream(nc);
          theVideo.attachVideo(ns);
          ns.setBufferTime(30);
          ns.onStatus = function(info) {
          //trace(info.code);
          if(info.code == "NetStream.Buffer.Full") {
          bufferClip._visible = false;
          if(info.code == "NetStream.Buffer.Empty") {
          bufferClip._visible = true;
          //if(info.code == "NetStream.Play.Stop") {
          //ns.seek(0);
          ns.play(vidPath);
          //ns.play(" http://www.portfolionewengland.com/interviews/rKukalis150.flv");
          playButton.onRelease = function() {
          ns.pause();
          rewindButton.onRelease = function() {
          ns.seek(0);
          var videoInterval = setInterval(videoStatus,100);
          var amountLoaded:Number;
          var duration:Number;
          ns["onMetaData"] = function(obj) {
          duration = obj.duration;
          function videoStatus() {
          amountLoaded = ns.bytesLoaded / ns.bytesTotal;
          loader.loadbar._width = amountLoaded * 208.9;
          loader.scrub._x = ns.time / duration * 208.9;
          var scrubInterval;
          loader.scrub.onPress = function() {
          clearInterval(videoInterval);
          scrubInterval = setInterval(scrubit,10);
          this.startDrag(false,0,this._y,208,this._y);
          loader.scrub.onRelease = loader.scrub.onReleaseOutside = function() {
          clearInterval(scrubInterval);
          this.stopDrag();
          function scrubit() {
          ns.seek(Math.floor((loader.scrub._x/208)*duration));
          var theMenu:ContextMenu = new ContextMenu();
          theMenu.hideBuiltInItems();
          _root.menu = theMenu;
          var item1:ContextMenuItem = new ContextMenuItem("::::: Video Controls :::::",trace);
          theMenu.customItems[0] = item1;
          var item2:ContextMenuItem = new ContextMenuItem("Play / Pause Video",pauseIt,true);
          theMenu.customItems[1] = item2;
          var item3:ContextMenuItem = new ContextMenuItem("Replay the Video",restartIt);
          theMenu.customItems[2] = item3;
          var item4:ContextMenuItem = new ContextMenuItem("© 2005 Lee Brimelow",trace,true);
          theMenu.customItems[3] = item4;
          function pauseIt() {
          ns.pause();
          function stopIt() {
          ns.seek(0);
          ns.pause();
          function restartIt() {
          ns.seek(0);
          _root.createEmptyMovieClip("vSound",_root.getNextHighestDepth());
          vSound.attachAudio(ns);
          var so:Sound = new Sound(vSound);
          so.setVolume(100);
          mute.onRollOver = function() {
          if(so.getVolume()== 100) {
          this.gotoAndStop("onOver");
          else {
          this.gotoAndStop("muteOver");
          mute.onRollOut = function() {
          this.gotoAndStop("on");
          else {
          this.gotoAndStop("mute");
          mute.onRelease = function() {
          so.setVolume(0);
          else {
          so.setVolume(100);
          stop();
          • 2. Re: Need to loop an FLV
            chopTheWood Level 1
            The following link gets you to a download page which includes an 8 part video tutorial on making a custom video player (where I got this code) which will explain about design and coding.
            http://www.gotoandlearn.com/download.php
            • 3. Re: Need to loop an FLV
              semx Level 1
              Dude thanks so much. I looked over that site but I guess I missed that tutorial. Thanks again!! If I figure it out, I'll post the results on here.
