0 Replies Latest reply on Mar 21, 2010 10:47 PM by ramos.eder
    Problems With Update Images
    ramos.eder
      I apply from FLEX to delete an image from a local server .
      The applicat n is a success, I make the request through a PHP script that I erase the image of the SRC folder and also in the BIN-DEBUG folder when I'm reviewing the local server the image was erased ... so the php script if it works.
      The problem is that the user interface ... always shows the image, I used the Bindable Metatag and I have assigned null to source property but did not work.
      I followed the advice of the Flex Builder Help Contents
      "If you find memory problems related to Images objects, try explicitly setting  the source property to null when you are done using the Image  object in your application."
