21 Replies Latest reply on Mar 22, 2010 6:50 AM by Norb11
    Combobox, how add items from array ?
    Norb11
      I have two  arrays   with items  (names and age),  and I want  add items from "names"  to   combo box using for  loop and add age to  input text using if statement   for exemple :
      if(names[i] == .x)
           mytextBox =age[i];
      I  added "combobox"   to my pdf and set  name "mycombo", and now I want add all item
      How I can do this using Java Script on Acrobat ?
      var i=0;
      for (i=0;i<names.length;i++){
           mycombo.setItem =names[i];
        • 1. Re: Combobox, how add items from array ?
          Problem 1: There's no such method as setItem, only setItems. Another option
          is insertItemAt.
          Problem 2: You can't use a method with the assignment operator '='. You must
          place the value you pass to it in parentheses.
          I suggest you go back to the reference files and have another look at these
          methods. There are examples there.
          • 2. Re: Combobox, how add items from array ?
            Norb11 Level 1
            Thank for reply,
            Can You  give me link to reference  and tell  me with chapter I must read?
            Im new acrobat user and  I don't have any experience with JS and adobe.
            • 3. Re: Combobox, how add items from array ?
              The reference is here:
              http://livedocs.adobe.com/acrobat_sdk/9.1/Acrobat9_1_HTMLHelp/JavaScript_SectionPage.70.1. html
              However, if you have no experience at all with JS expect a steep learning
              curve.
              • 4. Re: Combobox, how add items from array ?
                Norb11 Level 1
                Thank for link.
                I have some experience with JS, but  no  with adobe acrobat.
                OK, I try   to do   some like this:
                var starter = this.getField("starter");
                starter.editable = true;
                var j=0;
                    for(j=0; j<name.length;j++){
                        starter.insertItemAt(name[j],j);
                And after save and restart acrobat, when I click on  combobox, I don't have any exception,  only windows event  alert sound, and my combobox list is clear.
                When I choice "Debug from start"   from menu,
                i have this alert after clikc on combobox
                Acrobat JavaScript Debugger Functions Version 9.0
                Acrobat EScript Built-in Functions Version 9.0
                Acrobat Annotations / Collaboration Built-in Functions Version 9.0
                Acrobat Annotations / Collaboration Built-in Wizard Functions Version 9.0
                Acrobat SOAP 9.0
                Is this code is correct?
                I read  about this method on JS API  reference manula page:  458
                • 5. Re: Combobox, how add items from array ?
                  Where's the definition of the variable called "name"?
                  • 6. Re: Combobox, how add items from array ?
                    Norb11 Level 1
                    This is my code:
                    //-----------------Do not edit the XML tags--------------------
                    //<AcroForm>
                    //<ACRO_source>Starter:Annot1:MouseUp:Action1</ACRO_source>
                    //<ACRO_script>
                    /*********** belongs to: AcroForm:Starter:Annot1:MouseUp:Action1 ***********/
                    var temp =trustedDataGet();//get array
                    var tmp;
                    var name = new Object();
                    var date = new Object();
                    var nr = new Object();
                    var  i=0;
                    var j=0;
                    for(i =0;i<temp.length;i++){
                        tmp =temp[i].split(";");
                        name[i] =tmp[0]+" "+tmp[1];
                        date[i]=tmp[2];
                        nr[i]=tmp[3];
                    //    starter.insertItemAt(name[j],j);
                        console.println(name[j]);    //it doesn't work, I can't see it when I try  debug this code
                    //</ACRO_script>
                    //</AcroForm>
                    • 7. Re: Combobox, how add items from array ?
                      Where's "trustedDataGet" defined?
                      • 8. Re: Combobox, how add items from array ?
                        Norb11 Level 1
                        trustedDataGet  this is  function from "C:/Prog...Files/acr..... /Javascript/config.js",
                        this is function to get data from file,
                        My script from  previous post  work corrently to place when I try  add data to combobox. (line).
                        Problem is on  last loop.
                        But I  don't know when and why
                        • 9. Re: Combobox, how add items from array ?
                          Try defining name as an Array (instead of Object) and using the push()
                          method to add new items to it.
                          • 10. Re: Combobox, how add items from array ?
                            Norb11 Level 1
                            It works
                            This is  working code:
                            var name = [];// new Object();
                            var date = [];//new Object();
                            var nr = [];// new Object();
                            var  i=0;
                            var j=0;
                                name.push(tmp[1]+" "+tmp[0]);
                                date.push(tmp[2]);
                                nr.push(tmp[3]);
                               // console.println(name[j]);
                            I have next question, how automatical clear combobox after exit ( close pdf file) ?
                            for now, im add on start  :
                            this.getField("starter").clearItems();
                            And my last  question is,   how get the combobox numerical value
                                starter.insertItemAt(name[j],j); //  how get  "j"  value ?
                            • 11. Re: Combobox, how add items from array ?
                              I'm not sure what you mean. You can't change the file after it's closed.
                              You can either do it just before it closes (using the "WillClose" event), or
                              when it opens.
                              To clear a combo-box use the clearItems() method.
                              • 13. Re: Combobox, how add items from array ?
                                Norb11 Level 1
                                I  modify
                                my script,  im  add a part responsibility for load combobox items  to on open event,  and  next  when I click on combobox, I try  add some text to textbox,
                                this is my  code:
                                var  i=0;
                                //this.getField("starter").clearItems();
                                var  j=0;
                                    date.push(tmp[2]);
                                     nr.push(tmp[3]);
                                //</ACRO_script>
                                //</Page-Actions>
                                //<Page-Actions>
                                //<ACRO_source>Page1:Page  Close:Action1</ACRO_source>
                                //<ACRO_script>
                                /***********  belongs to: Page-Actions:Page1:Page Close:Action1 ***********/
                                //</ACRO_script>
                                //</Page-Actions>
                                //<AcroForm>
                                //<ACRO_source>starter:Annot1:MouseUp:Action1</ACRO_source>
                                //<ACRO_script>
                                /***********  belongs to: AcroForm:starter:Annot1:MouseUp:Action1 ***********/
                                //var  starter = this.getField("starter");
                                var dl = this.getField("Text10");
                                var  brith = this.getField("Text9");
                                brith.value=date[starter.index];
                                dl.value  =nr[starter.index];
                                On  last part, I  try  to add some value  to  textbox forms
                                but  I  can't see  any string from  arrays ("date", and "nr" ) on pdf document, I  don't have any error or warning ,   but  I see only "undefined"
                                Why? Or when I can see full combobox property list ?
                                which property have a value of current selected item ?
                                • 14. Re: Combobox, how add items from array ?
                                  You didn't define date or nr in the last script.
                                  • 15. Re: Combobox, how add items from array ?
                                    Norb11 Level 1
                                    No,
                                    I define this arrays  on script ( create this array in event , when  open document)
                                    all code:
                                    //<Page-Actions>
                                    //<ACRO_source>Page1:Page Open:Action1</ACRO_source>
                                    //<ACRO_script>
                                    /*********** belongs to: Page-Actions:Page1:Page Open:Action1 ***********/
                                    var temp =trustedDataGet();//get array var tmp;
                                    var tmp;
                                    var  i=0;
                                    var j=0;
                                        date.push(tmp[2]);
                                        nr.push(tmp[3]);
                                    //</ACRO_script>
                                    //</Page-Actions>
                                    //<Page-Actions>
                                    //<ACRO_script>
                                    //</ACRO_script>
                                    //</Page-Actions>
                                    //<AcroForm>
                                    //<ACRO_script>
                                    brith.value=date[starter.selectedIndex];
                                    dl.value =nr[starter.selectedIndex];
                                    //<AcroForm>
                                    //<ACRO_script>
                                    //</ACRO_script>
                                    //</AcroForm>
                                    All code is in this same file, so I think all variable is  global var.  ?
                                    • 16. Re: Combobox, how add items from array ?
                                      Norb11 Level 1
                                      No,
                                      all code:
                                      //<Page-Actions>
                                      //<ACRO_script>
                                      var tmp;
                                      var  i=0;
                                      var j=0;
                                           date.push(tmp[2]);
                                           nr.push(tmp[3]);
                                      //</ACRO_script>
                                      //</Page-Actions>
                                      //<Page-Actions>
                                      //<ACRO_script>
                                      //</ACRO_script>
                                      //</Page-Actions>
                                      //<AcroForm>
                                      //<ACRO_script>
                                      //<AcroForm>
                                      //<ACRO_script>
                                      //</ACRO_script>
                                      //</AcroForm>
                                      • 17. Re: Combobox, how add items from array ?
                                        No variable is global unless you define it as one. Look at the global object
                                        in the reference files.
                                        • 18. Re: Combobox, how add items from array ?
                                          Norb11 Level 1
                                          If this arrays isn't global, why  i can do this when I click on combobox?
                                          console.println(date[10]);
                                          this print string.
                                          But OK,   for now, I move  my code from event  (open file)  to  event click on combobox. (leater I move this part of code to  open file event)
                                          And now when I try do this:
                                          var driveLicense = this.getField("Text10");
                                          console.println(starter.selectedIndex);
                                          driveLicense.value =nr[starter.selectedIndex];
                                          i see "undefined"  on textbox
                                          starter.selectedIndex - is  OK?
                                          Maybe  I try  use wrong property?
                                          I use notepad++ as a editor,   when I choice ctrl+space keys  I can see long list  , but i don't know whitch property is OK
                                          • 19. Re: Combobox, how add items from array ?
                                            There's no such thing as selectedIndex. You need to use the reference files.
                                            Notepad++ doesn't have the special Acrobat objects built-in.
                                            • 20. Re: Combobox, how add items from array ?
                                              Norb11 Level 1
                                              I try search  on API reference and Developing Acrobat Aplication  but  I don't see property list of combobo on one place, table  or some  like that.
                                              i try use some property:
                                              numItems  -  return a int number of all  items, but  I need a numeber of selected item
                                              .so...  maybe   "value" .. ?
                                              Yes,  this is It
                                              Thank You Try67, thank you  for Your time and corectly answer.
                                              • 21. Re: Combobox, how add items from array ?
                                                You're welcome, but you can't program based on guesses...
                                                Try downloading this PDF reference file:
                                                http://www.adobe.com/devnet/acrobat/pdfs/AcroJS.pdf
                                                It's not for the latest version of Acrobat, but it's much easier to use than
                                                the online version, and the differences between it and the latest version
                                                are not that big.
                                                A combo-box is a field, so you need to look under the Field object for the
                                                properties and methods available for it.
