what is the difference between readResourceContent and ReadDocument services..
Why if i create file or folder from Write document\ Create Directory, then It is not visible from work bench...
if i create file using WriteDocument.. it shows created path
/apps/ki01/af-was61-pp01/AppServer/profiles/af-node61-pp
01-01/uploadfiles/Test.pdf
what is that... tell me differences...
Solved! Go to Solution.
Views
Total Likes
ReadResourceContent is used to read documents from the LiveCycle repository (the LiveCycle database). ReadDocument is for reading binary files from the server's file system (hard drive).
If you create a file with Write document\ Create Directory it goes on the servers file system - its hard drive - and not in the LiveCycle repository (the database). In fact the repository may be housed on a different server (in the case of a remote database). If you write a file to "/apps/ki01/af-was61-pp01/AppServer/profiles/af-node61-pp01-01/uploadfiles/Test.pdf" then check the server's hard drive then you will see the files are there. If its a Windows box check the C: drive for that file.
file system (hard drive) != repository (database)
Views
Total Likes
Views
Total Likes
Thank you so much Hodmi,...
thanks alot...
Views
Total Likes
