3 Replies Latest reply on Mar 26, 2010 3:05 PM by Linda Nicholls
    Chance of using Photoshop Brushes?
    ribery75
      Hi folks,
      is there a chance or workaround using the great amount of fantastic Photoshop brushes in Fireworks CS4?
      Kind regards from Germany
        • 1. Re: Chance of using Photoshop Brushes?
          Linda Nicholls Level 4
          A workaround might be to export the images, one at a time, and create a new common library folder with them. The steps are as follows:
          1-Open a new Document
          2-Open the Common Library panel menu and choose New Folder.
          3-Give the folder a name
          3-Add a brush image to the document.
          4-Export the document to your new folder. On my machine that's located at C:\Users\user name\AppData\Roaming\Adobe\Fireworks CS5\Common Library\My New Folder .
          5-Repeat for each image you want to add to your folder
          To use them, drag and drop them from the new folder in the Common Library panel
          • 2. Re: Chance of using Photoshop Brushes?
            ribery75 Level 1
            Hi Linda,
            thank you very mch for your answer!
            But I think I didn't get ya;-( What do you mean with "Add a brush image"? All the Photoshop Brushes I know are in the .abr-format which I only can open with Photoshop.
            By the way: Today I got the info that Fireworks CS5 (it seems that you'r one of the lucky Beta-testes if I look at your Folder-link:-) can handle Photoshop brushes!
            Kind regards
            Thomas
            • 3. Re: Chance of using Photoshop Brushes?
              "But  I think I didn't get ya;-( What do you mean with "Add a brush image"?  All the Photoshop Brushes I know are in the .abr-format which I only can  open with Photoshop."
              I meant drop an image from a brush in Photoshop, and then export it. Follow the rest of the instructions from above. That was meant to discourage you, by the way. I hate Photoshop brushes. :-)
              "By the way: Today I got the info that Fireworks  CS5 (it seems that you'r one of the lucky Beta-testes if I look at your  Folder-link:-) can handle Photoshop brushes!"
              I can't say. :-)
              Linda
