7 Replies Latest reply on Mar 22, 2010 6:28 PM by alice_data
    Constructor functions must be instance methods?
    alice_data
      I have this code as in the following:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
              <![CDATA[
                  import mx.controls.*;
                  import mx.events.*;
                  import mx.containers.*;
                  import thematicMap.*;
                   public var Region:Region = new Region();
                   public var Scale:Scale = new Scale();
                   public var ThematicMap:ThematicMap = new ThematicMap(); //1026:Constructor functions must be instance methods
                   public var ReadXML:ReadXML = new ReadXML();
                   private var savedIndex:int= 99999;
                    public function addNavigation():void{
                        var buttonTools:Array = ["Driving Distance","Education Level--College",
                                                 "Education Level--High School","Median Income","Population"];
                        var navigationBar:ToggleButtonBar = new ToggleButtonBar();
                            navigationBar.dataProvider = buttonTools;
                            navigationBar.toggleOnClick = true;
                            navigationBar.selectedIndex = -1;
                            navigationBar.addEventListener(ItemClickEvent.ITEM_CLICK,clickHandler);
                            //pass the variables?
                            addSlider(); //add the slider control
                            vbox.addChild(navigationBar);
                    public function addSlider():void{
                         var text_entry:HBox = new HBox();
                         var numColors:TextInput = new TextInput();
                             numColors.length == 3;
                             numColors.text = "5";
                             numColors.restrict = "0-9";
                         var direction:Text= new Text();
                             direction.text = "Number of Colors";
                          //recalculate the map if the listener is called
                         text_entry.addChild(direction);
                         text_entry.addChild(numColors);
                         vbox.addChild(text_entry);
                   public function clickHandler(event:ItemClickEvent):void{
                       if(event.index == savedIndex) {
                           //don't do a thing
                       else savedIndex = event.index;
                       //add the thematic map
                       ThematicMap.addRegions(OK); //This part never worked
                       //mapGrid.addChild(thematicmap);
          </mx:Script>
         <mx:Canvas id="map" creationComplete="addNavigation()">
                 <mx:VBox id="vbox" x="20" y="10">
                 <mx:Canvas id="mapGrid"/>
          </mx:VBox>
         </mx:Canvas>
      </mx:Application>
      Here is what I have in my ThematicMap.as:
      package thematicMap
          import mx.core.*;
          import mx.events.*;
          public class ThematicMap {
              public var region:Region = new Region();
              public var readXML:ReadXML = new ReadXML();
              public function addRegions(name:String):void {
                   trace(name);
      Have I done something wrong here? How come it keeps telling me that the constructor functions must be instance methods?
      Thanks for your help.
      Alice
        • 1. Re: Constructor functions must be instance methods?
          jphillipcamp
          Add a constructor function as seen below:
          package thematicMap
              import mx.core.*;
              import mx.events.*;
                  public function ThematicMap() {}
                       trace(name);
          I hope this helps!
          Best,
          J. Phillip Camp
          • 2. Re: Constructor functions must be instance methods?
            alice_data Level 1
              I took your advice, and looks like it does not seem to work. Instead, I changed all my variable instances of these "classes" to lowercase, and that helped. For some reason, the error I get now refers to the function I tried to get to work earlier now shows up by teling me I am caling an possibly undefined method addRegions through a reference with static type ThematicMap, and there is an undefined property OK.
            Here is the code in my ThematicMap class:
              package thematicMap
                import mx.core.*;
                import mx.events.*;
                         trace(name);
            And, in my app:
                                 //don't do a thing
                             thematicMaps.addRegions(OK);
            Anyone has any ideas on what this might be?
            Alice
            • 3. Re: Constructor functions must be instance methods?
              jphillipcamp Level 1
              All variables should always start lowercase.  Otherwise the compiler will think they are classes.  Also but quotes around ok and you should be good to go!
                thematicMaps.addRegions("OK");
              • 4. Re: Constructor functions must be instance methods?
                alice_data Level 1
                Yes, I put in the quotes, and that took care of that error.
                However, it still tells me I have an error that I am calling a possibly undefined method addRegions through a reference with static type ThematicMap
                Here is the complete code of my main app:
                    <mx:Script>
                        <![CDATA[
                            import mx.events.*;
                            import thematicMap.*;   //I had imported all the classes
                             public var scale:Scale = new Scale();
                             public var thematicMaps:ThematicMap = new ThematicMap();
                                  var buttonTools:Array = ["Driving Distance","Education Level--College",  "Education Level--High School","Median Income","Population"];
                                     //don't do a thing
                    </mx:Script>
                    </mx:VBox>
                   </mx:Canvas>
                </mx:Application>
                As a matter of fact, when I write import thematicMap. it looks like thematicMap.ThematicMap does show up, so that is imported, right?
                I am getting confused.
                Alice
                • 5. Re: Constructor functions must be instance methods?
                  I copied your code and got it to compile with a few hitches:
                  • I had to make sure ThematicMap.as was in the thematicMap directory in the source so the package name was correct.
                  • I had to check all the spelling of the file names and directories (I have typo issues - I had typed ThermaticMap, and I was getting a similar issue to yours)
                  • I had to comment out Region, Scale and ReadXML
                  Other than that, it worked.  I'd check the file name, directory structure, and package name and go from there.
                  • 6. Re: Constructor functions must be instance methods?
                    Flex harUI Adobe Employee
                    Clean and rebuild then show us exactly the error and what line.
                    • 7. Re: Constructor functions must be instance methods?
                      alice_data Level 1
                      My code is now working great thanks to the users who replied to the posts. I changed the name of the class, and that solved the other part of the problem.
                      Thanks.
                      Alice
