8 Replies Latest reply on Mar 30, 2010 10:42 PM by Abhik_GlobalLogic
    Flex Builder Won't Launch?
    packjallo
      I recently downloaded the trial for Adobe Flex Builder 4 and when opening the program all i get is a message saying 'An error has occoured, please see log file'. I had the same problem when trying Flex 3.
      Can anyone help? Ive tried everything I can find, ive also tried uninstalling it and re-installing it. I am running Mac OSX 10.6.2
        • 1. Re: Flex Builder Won't Launch?
          Jason San Jose Adobe Employee
          Can you post what's in your log file? /Users/you/Documents/Adobe Flash Builder 4/.metadata/.log?
          Jason San Jose
          Software Engineer, Flash Builder
          • 2. Re: Flex Builder Won't Launch?
            packjallo Level 1
            I can't see any log, there is a configuration folder and a p2 folder.
            I also don't have any problems running other CS4 programs on my mac so perhaps it won't run off Eclipse.
            • 3. Re: Flex Builder Won't Launch?
              Which distribution did you use: standalone or plug-in?
              Jason San Jose
              • 4. Re: Flex Builder Won't Launch?
                packjallo Level 1
                Standalone
                • 5. Re: Flex Builder Won't Launch?
                  Without knowing much more, try this:
                  1) Applications > Utilities > Java Preferences
                  2) You should have a 32-bit option under "Java Applications", drag that option to the top of the list
                  3) Try starting Flash Builder
                  Other things that can cause issues:
                  - Eclipse Cocoa is not supported
                  - Eclipse 64-bit is not supported
                  ...see http://www.adobe.com/products/flex/systemreqs/
                  Jason San Jose
                  • 6. Re: Flex Builder Won't Launch?
                    Abhik_GlobalLogic
                    I've installed Flash Builder 4 RC in my windows XP workstation, but it crashes every time I try to launch the application. I found this error in C:\Documents and Settings\<User>\Adobe Flash Builder 4\.metadata\.log
                    !SESSION 2010-03-30 14:14:14.656 -----------------------------------------------
                    eclipse.buildId=unknown
                    java.version=1.6.0_16
                    java.vendor=Sun Microsystems Inc.
                    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
                    Command-line arguments:  -os win32 -ws win32 -arch x86
                    !ENTRY org.eclipse.equinox.ds 4 0 2010-03-30 14:14:15.453
                    !MESSAGE
                    !STACK 0
                    org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.equinox.internal.util.event; version="1.0.0"
                    at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.j ava:1313)
                    at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(Abs tractBundle.java:1297)
                    at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:309)
                    at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:370)
                    at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1068)
                    at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManage r.java:557)
                    at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java :464)
                    at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelMana ger.java:248)
                    at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManage r.java:445)
                    at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
                    at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
                    Any idea, how to fix this?
                    • 7. Re: Flex Builder Won't Launch?
                      This sounds like another thread http://forums.adobe.com/message/2696996#2696996.
                      Can you provide more details about the crash? Users on the other thread are having the same problem but I don't think I've seen/asked for a screenshot of the crash.
                      Please attach the following log C:\Documents and Settings\User\Local Settings\Temp\amt3.log
                      Jason San Jose
                      • 8. Re: Flex Builder Won't Launch?
                        Abhik_GlobalLogic Level 1
                        Hi Jason,
                        Said log file is to big to post in forum so, attaching the file with this e-mail. Please let me know if you need any other information.
                        Thanks & regards,
                        Abhik
