1. Re: understanding URLResource
RyanOConnell Mar 22, 2010 2:36 PM (in response to kutu182)Hi -
One thing looks out of place about your example is the .mp4 extension on the video. Streams of H.264 content don't normally need the extension. The other caveat is if the FMS server you are using has instances, you'll need to use a StreamingURLResource instead of a URLResource, and pass the urlIncludesFMSApplicationInstance as true. A good sanity check is to test your url again the Flex VideoDisplay component, or the FLVPLayback component.
2. Re: understanding URLResource
codingNub Mar 22, 2010 2:37 PM (in response to kutu182)In sprint 9 I have it working like this.
v = new VideoElement(new NetLoader(), new URLResource(new URL(videoURL)));
3. Re: understanding URLResource
codingNub Mar 22, 2010 2:47 PM (in response to codingNub)So instead of URL it would be..
v = new VideoElement(new NetLoader(), new URLResource(new FMSURL('rtmp.url'))));
4. Re: understanding URLResource
kutu182 Mar 22, 2010 3:03 PM (in response to RyanOConnell)hi codingNub,
thx, but i use sprint10, osmf 0.93, no classes URL and FMSURL.
hi RyanOConnell,
still not working
<s:VideoDisplay source="rtmp://mysite.org/mp4:video.mp4"/>
not working too
But, why so difficulty, i just want connect to "rtmp://mysite.org" and play "mp4:video.mp4"
Can i do that instead StreamingURLResource, but continue use osmf, because it awesome?
thx
5. Re: understanding URLResource
RyanOConnell Mar 22, 2010 3:11 PM (in response to kutu182)If it doesn't work with the Flex VideoDisplay class, it's most likely the wrong URL. This can be the result of a typos or missing application. Could you post your URL? If not, the general format is rtmp://myserver.com/myApplication/myvideo . Your example URL seems to be missing an application.
6. Re: understanding URLResource
codingNub Mar 22, 2010 3:21 PM (in response to RyanOConnell)Test this in your app.
var v:VideoElement = new VideoElement(new URLResource(REMOTE_STREAM)); private static const REMOTE_STREAM:String = "rtmp://cp67126.edgefcs.net/ondemand/mediapm/strobe/content/test/SpaceAloneHD_sounas_640_500_short";
That's taken directly from the examplePlayer inside trunk.
7. Re: understanding URLResource
bmishkin Apr 21, 2010 3:38 PM (in response to RyanOConnell)Hey thanks.
Not setting urlIncludesFMSApplicationInstance=true had been my problem for several hours today. This is the only place I have seen it mentioned.
If you are using LimeLight's CDN to deliver mp4, you need to set urlIncludesFMSApplicationInstance=true.
Cheers,
Ben Mishkin
Sagebit, LLC
8. Re: understanding URLResource
Bob Wohl Apr 21, 2010 3:52 PM (in response to bmishkin)Hi Ben,
Not only LimeLight uses instances. Application and application instances are
used quite a bit in the FMS world and the file type wouldn't have anything
to do with the app instance. Sounds like a uri issue or a parse issue
between the stream name and connection string. So you are saying that
setting this value to true resolves an issue with mp4s and not needed for
flvs?
Bob
9. Re: understanding URLResource
bmishkin Apr 22, 2010 4:51 AM (in response to Bob Wohl)Yes.
We use Limelight CDN, which uses application instances. But I hadn't even noticed that we needed to set urlIncludesFMSApplicationInstance=true, because our flv URLs of the form
rtmpe://llnwqa.fcod.llnwd.net/a1218/o18/quickstart/limelight_sample_flashmovie
(which assumes the '.flv' extension)
were working without it. But when we tried an mp4, like
rtmp://llnwqa.fcod.llnwd.net/a1218/018/mp4:path/to/test.mp4
the video would not load until we set urlIncludesFMSApplicationInstance=true.
10. Re: understanding URLResource
Bob Wohl Apr 22, 2010 10:03 AM (in response to bmishkin)Ah, that doesn't sound right being the instance has nothing to do with the
file type and adding the prefix. Maybe some one at adobe can confirm that
this is intentional and working as intended.
Thanks for the heads up on this Ben.
Bob
11. Re: understanding URLResource
bringrags Apr 23, 2010 8:39 AM (in response to Bob Wohl)Bob is right, it doesn't have anything to do with the file type or prefix. For the first URL, it turns out that we can establish a connection with or without urlIncludesFMSApplicationInstance. When set to false, it connects to:
rtmpe://llnwqa.fcod.llnwd.net:1935/a1218
When set to true, it connects to:
rtmpe://llnwqa.fcod.llnwd.net:1935/a1218/o18
Not sure why both URLs work, but in general you should stick with the true param for Limelight streams.
