0 Replies Latest reply on Mar 22, 2010 9:18 PM by luckliuyi
    easyLoader,be more stronger,more simple!load all types of files in one way!
    luckliuyi Level 1
      Hi,guys!Very happy to announce to the world,my easyLoader project was updated to 1.012.
                this class can be used to load sound,video,txt,xml,image,swf,event dae and on.and you guys can add custom file type for easyLoader.
                author :liuyi email:ourbrander@gmail.com,
      Home and document online!:http://www.ourbrander.com/easyloader/
      Google code:https://code.google.com/p/easyloader/
                What is easyLoader?
                This work is use load all the assets of  website or game,it is an good assets manager.
                People can use it to load sound,video,txt,xml,image,swf,dae and any custom  types of files.
                Why we need it?
                -easy of use
                         Every method have a good naming,you can use it likes speak to an friend.Only need several lines to complete the work.
                -never be lost items
                  load items one by one.
                -excellent memory manage
                         Using it continually more than 24 hours,memory do not increase without limit.item can be destoried,easyLoader Object(include all assets) too.
                -flexible
                        User can add custom file type to loading.
                -dynamic add items for easyLoader
                 EasyLoader can add and load new assets anytime and anywhere,although all the items were loaded.
                -Updates
                 will updates according to user's requirements.
                How to use?
                Realy only need several lines:
                step1:
                new a easyLoader Object
                line1: var _assetsManager = new EasyLoader();
                step2:
                add some necessary event Listener
                line2: _assetsManager.addEventListener(EasyLoaderEvent.COMPLETED,assetsLoaded)
                step3:add the assetsLoaded function
                line2:private function assetsLoaded(e:EasyLoaderEvent) {
                 line3:     //put some code to here like init()
                 line4:}
                 step4:load assets according to config xml
                 line5:_assetsManager.loadConfig("assets.xml")
                 ok,this is all!
      Public Methods
      EasyLoader()
      addFile(path:String, alias:String = "", loadTip:String = "", autoRemove:Boolean = false, method:String = "text"):void
      addType($type:String, $name:String):Boolean
      dispose():void
      disposeFileByAlias(alias:String):Boolean
      disposeFileByName(name:String):Boolean
      getFileByAlias(alias:String):LoadedItem
      getFileByIndex(number:uint):LoadedItem
      getFileByName(name:String):LoadedItem
      init(obj:* = null, $autoLoad:Boolean = true, $ignoreError:Boolean = true):Boolean
      loadConfig(str:String):void
      pause():void
      removeFileByAlias(alias:String):Boolean
      removeFileByName(name:String):Boolean
      start():void
      unPause():void
