1. Re: cfwindow CF8
Newsgroup_User Sep 13, 2007 8:09 PM (in response to Ronsweb)your code shows the cfwindow on page's load in my tests without a problem...
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com -
2. Re: cfwindow CF8
Ronsweb Sep 14, 2007 10:06 AM (in response to Newsgroup_User)Azadi,
It is throwing a javascript error.
In your internet options in IE under advanced; uncheck disable script debugging.
It will throw an javascript error.
Thanks.
Ron -
3. Re: cfwindow CF8
Newsgroup_User Sep 16, 2007 7:35 PM (in response to Newsgroup_User)Ronsweb wrote:
> Azadi,
> Thanks.
> Ron
hmm... i see what you mean.... it seems to error only in IE, though...
every other browser (well, FF, Safari, Opera and Netscape) show the
window no problem...
IE complains about line 90 in /CFIDE/scripts/ajax/package/cfajax.js
file... not sure why...
as a workaround, any reason you can't use initshow="true" in your
<cfwindow> tag?
Azadi Saryev
Sabai-dee.com
4. Re: cfwindow CF8
hevsys Nov 21, 2009 8:46 AM (in response to Newsgroup_User)Yes, you are correct if you use the initShow="true" this will resolve your issue. But consider this, I wanted to refresh a page after the window closes
so I started with.
<script>
function wrefresh() {
location.href = 'refresh.cfm';
}function wload() {
ColdFusion.Window.onHide('register', wrefresh);
</script>and I called from the body tag just as the author did the difference is I was calling from a button on the page, I do not want the
window to load by default. I too got the line 90 error in IE. Resolution was not to call the open window from the button, to call
the javascript from the button and add the show window to it. Load nothing on the body tag.
<script>
}function wload() {
ColdFusion.Window.show('register');
</script><a href="##" id="menu_link" onclick="wload();">
Posting for reference.
5. Re: cfwindow CF8
injun [576871] Nov 21, 2009 11:51 AM (in response to Ronsweb)Hi!
In cfwindow tag change initshow=false to initshow=true
And all be OK
6. Re: cfwindow CF8
hevsys Nov 21, 2009 12:40 PM (in response to injun [576871])Hi, Sorry you missed the point that I did NOT want the page
to load by default. I have no issue, just posted my resolution in this thread
for reference.
