5 Replies Latest reply on Mar 23, 2010 1:02 PM by Jacob Bugge
    placing images on a path
    whytefly Level 1
      i have multiple images i want to place on a cruved path. how can i go about doing this?
      cheers,
        • 1. Re: placing images on a path
          Junk Mailer Level 3
          I would draw the path and then turn on Smart Guides (CMD+U) to snap a particular point on the images along the path. See my attached screenshot. I did this with rectangles, but you could also use placed images. Then just delete the curved line when you are done using it for placement.
          • 2. Re: placing images on a path
            Junk Mailer Level 3
            ...or you could use InDesign. It allows you to insert images into a line of text, even text typed onto a path. See my screenshot:
            • 3. Re: placing images on a path
              Jacob Bugge MVP & Adobe Community Professional
              Whytefly,
              If you want a regular distribution along the path, you may:
              1) Create a Scatter Brush from a rectangle of the same size, setting the distance as desired, and having the orientation aligned to Page or to Path (to follow the path);
              2) Apply the Scatter Brush to the path and adjust;
              3) Object>Expand the brushed path to have the rectangles selectable;
              4) Place each image and Align>Align Objects vertically and horizontally centred;
              5) If aligned to Path, turn to fit the angle;
              6) DirectSelect and Remove the rectangles.
              • 4. Re: placing images on a path
                Junk Mailer Level 3
                I thought about doing it this way, but I was worried about distortion
                (stretching). Would this cause any distortion in the images?
                • 5. Re: placing images on a path
                  JM,
                  As far as I know there should be no distortion possible apart from small unavoidable inaccuracy when rotating, the basic concept being a scattered pattern, and I have not seen any when used.
