0 Replies Latest reply on Mar 23, 2010 9:05 AM by Carol L. Frampton
    [svn:fx-4.x] 14940: The Scroller, Vscroller and Hscroller mouseWheel handlers are sitting in a loop doing gets /sets on the viewport?\226?\128?\153s scroll position.
    Carol L. Frampton Level 2
      Revision: 14940
      Revision: 14940
      Author:   cframpto@adobe.com
      Date:     2010-03-23 09:05:02 -0700 (Tue, 23 Mar 2010)
      Log Message:
      The Scroller, Vscroller and Hscroller mouseWheel handlers are sitting in a loop doing gets/sets on the viewport?\226?\128?\153s scroll position.  If the viewport is IInvalidating, validateNow() needs to be called to force the set and scroll to take place immediately so the next call to get the scroll delta will return an accurate result.  See SDK-25740 for a more complete solution which should be implemented in 4.5.
      QE notes:
      Doc notes: None
      Bugs: SDK-25250
      Reviewed By: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25740
          http://bugs.adobe.com/jira/browse/SDK-25250
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/HScrollBar.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/VScrollBar.as
