2 Replies Latest reply on Mar 23, 2010 11:47 AM by Xellon Night
    center a sfw file
    Xellon Night Level 1
      How do you center a swf file? And where would you place it in the html after publishing your file?
      EDIT:
      Here is my code after it is published:
      <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
      <title>Final</title>
      <script language="JavaScript" type="text/javascript">
      //v1.7
      // Flash Player Version Detection
      // Detect Client Browser type
      // Copyright 2005-2008 Adobe Systems Incorporated.  All rights reserved.
      var isIE  = (navigator.appVersion.indexOf("MSIE") != -1) ? true : false;
      var isWin = (navigator.appVersion.toLowerCase().indexOf("win") != -1) ? true : false;
      var isOpera = (navigator.userAgent.indexOf("Opera") != -1) ? true : false;
      function ControlVersion()
          var version;
          var axo;
          var e;
          // NOTE : new ActiveXObject(strFoo) throws an exception if strFoo isn't in the registry
          try {
              // version will be set for 7.X or greater players
              axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.7");
              version = axo.GetVariable("$version");
          } catch (e) {
          if (!version)
              try {
                  // version will be set for 6.X players only
                  axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.6");
                  // installed player is some revision of 6.0
                  // GetVariable("$version") crashes for versions 6.0.22 through 6.0.29,
                  // so we have to be careful.
                  // default to the first public version
                  version = "WIN 6,0,21,0";
                  // throws if AllowScripAccess does not exist (introduced in 6.0r47)
                  axo.AllowScriptAccess = "always";
                  // safe to call for 6.0r47 or greater
              } catch (e) {
          if (!version)
              try {
                  // version will be set for 4.X or 5.X player
                  axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash.3");
              } catch (e) {
          if (!version)
              try {
                  // version will be set for 3.X player
                  version = "WIN 3,0,18,0";
              } catch (e) {
          if (!version)
              try {
                  // version will be set for 2.X player
                  axo = new ActiveXObject("ShockwaveFlash.ShockwaveFlash");
                  version = "WIN 2,0,0,11";
              } catch (e) {
                  version = -1;
          return version;
      // JavaScript helper required to detect Flash Player PlugIn version information
      function GetSwfVer(){
          // NS/Opera version >= 3 check for Flash plugin in plugin array
          var flashVer = -1;
          if (navigator.plugins != null && navigator.plugins.length > 0) {
              if (navigator.plugins["Shockwave Flash 2.0"] || navigator.plugins["Shockwave Flash"]) {
                  var swVer2 = navigator.plugins["Shockwave Flash 2.0"] ? " 2.0" : "";
                  var flashDescription = navigator.plugins["Shockwave Flash" + swVer2].description;
                  var descArray = flashDescription.split(" ");
                  var tempArrayMajor = descArray[2].split(".");
                  var versionMajor = tempArrayMajor[0];
                  var versionMinor = tempArrayMajor[1];
                  var versionRevision = descArray[3];
                  if (versionRevision == "") {
                      versionRevision = descArray[4];
                  if (versionRevision[0] == "d") {
                      versionRevision = versionRevision.substring(1);
                  } else if (versionRevision[0] == "r") {
                      if (versionRevision.indexOf("d") > 0) {
                          versionRevision = versionRevision.substring(0, versionRevision.indexOf("d"));
                  var flashVer = versionMajor + "." + versionMinor + "." + versionRevision;
          // MSN/WebTV 2.6 supports Flash 4
          else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.6") != -1) flashVer = 4;
          // WebTV 2.5 supports Flash 3
          else if (navigator.userAgent.toLowerCase().indexOf("webtv/2.5") != -1) flashVer = 3;
          // older WebTV supports Flash 2
          else if (navigator.userAgent.toLowerCase().indexOf("webtv") != -1) flashVer = 2;
          else if ( isIE && isWin && !isOpera ) {
              flashVer = ControlVersion();
          return flashVer;
      // When called with reqMajorVer, reqMinorVer, reqRevision returns true if that version or greater is available
      function DetectFlashVer(reqMajorVer, reqMinorVer, reqRevision)
          versionStr = GetSwfVer();
          if (versionStr == -1 ) {
              return false;
          } else if (versionStr != 0) {
              if(isIE && isWin && !isOpera) {
                  // Given "WIN 2,0,0,11"
                  tempArray         = versionStr.split(" ");     // ["WIN", "2,0,0,11"]
                  tempString        = tempArray[1];            // "2,0,0,11"
                  versionArray      = tempString.split(",");    // ['2', '0', '0', '11']
              } else {
                  versionArray      = versionStr.split(".");
              var versionMajor      = versionArray[0];
              var versionMinor      = versionArray[1];
              var versionRevision   = versionArray[2];
                  // is the major.revision >= requested major.revision AND the minor version >= requested minor
              if (versionMajor > parseFloat(reqMajorVer)) {
                  return true;
              } else if (versionMajor == parseFloat(reqMajorVer)) {
                  if (versionMinor > parseFloat(reqMinorVer))
                      return true;
                  else if (versionMinor == parseFloat(reqMinorVer)) {
                      if (versionRevision >= parseFloat(reqRevision))
                          return true;
              return false;
      function AC_AddExtension(src, ext)
        if (src.indexOf('?') != -1)
          return src.replace(/\?/, ext+'?');
        else
          return src + ext;
      function AC_Generateobj(objAttrs, params, embedAttrs)
        var str = '';
        if (isIE && isWin && !isOpera)
          str += '<object ';
          for (var i in objAttrs)
            str += i + '="' + objAttrs[i] + '" ';
          str += '>';
          for (var i in params)
            str += '<param name="' + i + '" value="' + params[i] + '" /> ';
          str += '</object>';
        else
          str += '<embed ';
          for (var i in embedAttrs)
            str += i + '="' + embedAttrs[i] + '" ';
          str += '> </embed>';
        document.write(str);
      function AC_FL_RunContent(){
        var ret =
          AC_GetArgs
          (  arguments, ".swf", "movie", "clsid:d27cdb6e-ae6d-11cf-96b8-444553540000"
           , "application/x-shockwave-flash"
        AC_Generateobj(ret.objAttrs, ret.params, ret.embedAttrs);
      function AC_SW_RunContent(){
        var ret =
          AC_GetArgs
          (  arguments, ".dcr", "src", "clsid:166B1BCA-3F9C-11CF-8075-444553540000"
           , null
      function AC_GetArgs(args, ext, srcParamName, classid, mimeType){
        var ret = new Object();
        ret.embedAttrs = new Object();
        ret.params = new Object();
        ret.objAttrs = new Object();
        for (var i=0; i < args.length; i=i+2){
          var currArg = args[i].toLowerCase();
          switch (currArg){
            case "classid":
              break;
            case "pluginspage":
              ret.embedAttrs[args[i]] = args[i+1];
              break;
            case "src":
            case "movie":
              args[i+1] = AC_AddExtension(args[i+1], ext);
              ret.embedAttrs["src"] = args[i+1];
              ret.params[srcParamName] = args[i+1];
              break;
            case "onafterupdate":
            case "onbeforeupdate":
            case "onblur":
            case "oncellchange":
            case "onclick":
            case "ondblclick":
            case "ondrag":
            case "ondragend":
            case "ondragenter":
            case "ondragleave":
            case "ondragover":
            case "ondrop":
            case "onfinish":
            case "onfocus":
            case "onhelp":
            case "onmousedown":
            case "onmouseup":
            case "onmouseover":
            case "onmousemove":
            case "onmouseout":
            case "onkeypress":
            case "onkeydown":
            case "onkeyup":
            case "onload":
            case "onlosecapture":
            case "onpropertychange":
            case "onreadystatechange":
            case "onrowsdelete":
            case "onrowenter":
            case "onrowexit":
            case "onrowsinserted":
            case "onstart":
            case "onscroll":
            case "onbeforeeditfocus":
            case "onactivate":
            case "onbeforedeactivate":
            case "ondeactivate":
            case "type":
            case "codebase":
            case "id":
              ret.objAttrs[args[i]] = args[i+1];
              break;
            case "width":
            case "height":
            case "align":
            case "vspace":
            case "hspace":
            case "class":
            case "title":
            case "accesskey":
            case "name":
            case "tabindex":
              ret.embedAttrs[args[i]] = ret.objAttrs[args[i]] = args[i+1];
              break;
            default:
              ret.embedAttrs[args[i]] = ret.params[args[i]] = args[i+1];
        ret.objAttrs["classid"] = classid;
        if (mimeType) ret.embedAttrs["type"] = mimeType;
        return ret;
      </script>
      </head>
      <body bgcolor="#ffffff">
      <!--url's used in the movie-->
      <!--text used in the movie-->
      <p align="center"></p>
      <p align="left"></p>
      <!-- saved from url=(0013)about:internet -->
          AC_FL_RunContent(
              'codebase', 'http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0',
              'width', '1024',
              'height', '768',
              'src', 'Final',
              'quality', 'high',
              'pluginspage', 'http://www.adobe.com/go/getflashplayer',
              'align', 'middle',
              'play', 'true',
              'loop', 'true',
              'scale', 'showall',
              'wmode', 'window',
              'devicefont', 'false',
              'id', 'Final',
              'bgcolor', '#ffffff',
              'name', 'Final',
              'menu', 'true',
              'allowFullScreen', 'false',
              'allowScriptAccess','sameDomain',
              'movie', 'Final',
              'salign', ''
              ); //end AC code
      </script>
      <noscript>
          <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=10,0,0,0" width="1024" height="768" id="Final" align="middle">
          <param name="allowScriptAccess" value="sameDomain" />
          <param name="allowFullScreen" value="false" />
          <param name="movie" value="Final.swf" /><param name="quality" value="high" /><param name="bgcolor" value="#ffffff" />    <embed src="Final.swf" quality="high" bgcolor="#ffffff" width="1024" height="768" name="Final" align="middle" allowScriptAccess="sameDomain" allowFullScreen="false" type="application/x-shockwave-flash" pluginspage="http://www.adobe.com/go/getflashplayer" />
          </object>
      </noscript>
      </body>
      </html>
      Message was edited by: Xellon Night
        • 1. Re: center a sfw file
          RossRitchey Level 4
          There are several things you can do.
          1. You can make the Flash 100% width and height, set the scaleMode to "noScale" and the align to "M" (ideally, the scaleMode and align would be set in the SWF, not in the embed script).
          in SWF AS2:
          Stage.align = "M";
          Stage.scaleMode = "noScale";
          in SWF AS3: //AS3 automatically aligns middle
          stage.scaleMode = StageScaleMode.NO_SCALE;
          2. You can drop the Flash into a div (wrap the script/noscript block with it) and then use CSS to position the div at the center of the page.
          CSS:
          #FlashDiv {
               position:absolute;
               left:50%;
               top:50%;
               margin-left:-512px; /* This is exactly half the width of the Flash */
               margin-top:-384px; /* This is exactly half the height of the Flash */
               width:1024px; /* This is the width of the Flash */
               height:768px; /* This is the height of the Flash */
          HTML:
          <div id="FlashDiv">
          <!-- script/noscript block you are currently using -->
          </div>
          I prefer method 1 myself (100% width and height) if the page only contains the SWF - as it is more elegant, and less code than the CSS method.
          • 2. Re: center a sfw file
            thank you. I will try this later.
