0 Replies Latest reply on Mar 23, 2010 11:45 AM by Jason Szeto
    [svn:fx-4.x] 14946: ColorPicker and PopUpButton mirroring bug fix
    Jason Szeto Level 3
      Revision: 14946
      Revision: 14946
      Author:   jszeto@adobe.com
      Date:     2010-03-23 11:45:37 -0700 (Tue, 23 Mar 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-25916 - color/label field in swatch panel isn't updated when layoutDirection is
      changed between rtl and ltr
      Since the ColorPicker's SwatchPanel is parented by the SystemManager it wasn't inheriting the layoutDirection and it wasn't invalidating the layoutDirection. The fix is to pass the layoutDirection to the SwatchPanel and always call invalidateLayoutDirection in PopUpManager.addPopUp.
      http://bugs.adobe.com/jira/browse/SDK-25828 - initial popup starts with wrong position, not aligned with PopupButton when there is padding set on container
      The popup is not guaranteed to know its size until it has been added as a popup. Moved the position logic to after the popup has been added.
      QE notes: test mirrored ColorPicker and PopUpButton
      Doc notes: none
      Bugs: SDK-25916
      Reviewer: Carol
      Tests run: checkintests, ColorPicker, PopUpButton
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/PopUpButton.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
