0 Replies Latest reply on Mar 23, 2010 12:02 PM by Jason Szeto
    [svn:fx-4.x] 14947: Mirroring code hinting fixes
    Jason Szeto Level 3
      Revision: 14947
      Revision: 14947
      Author:   jszeto@adobe.com
      Date:     2010-03-23 12:02:19 -0700 (Tue, 23 Mar 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-25565 - Components should define metadata for  layoutDirection and direction styles
      There is both a style and property called layoutDirection in UIComponent. For UIComponent, both Hans and I agree that we should promote the use of the style. I added an exclude for the layoutDirection property in UIComponent. This allows code hinting for the layoutDirection style in the CSS style declaration. It also removes the layoutDirection property from the ASDoc. Code hinting still works for the layoutDirection attribute on a UIComponent subclass MXML tag. This attribute gets set to the property, not the style.
      ProgressBar has both a direction property and style. However, in this situation, they control different behaviors. It is not possible to code hint for the direction style in the CSS style declaration without removing the direction property from ASDoc. We are just going to have to live with this limitation.
      http://bugs.adobe.com/jira/browse/SDK-25823 - The layoutDirection style/property doesnt code hint static enums
      Added Inspectable metadata to BitmapAsset, SpriteAsset, SpriteVisualElement and GraphicElement.
      QE notes: test code hinting for layoutDirection
      Doc notes: none
      Bugs: SDK-25565, SDK-25823
      Reviewer: Carol, Hans
      Tests run: checkintests, Mirroring
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/BitmapAsset.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/SpriteAsset.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/primitives/supportClasses/Graph icElement.as
