0 Replies Latest reply on Mar 23, 2010 1:11 PM by Carol L. Frampton
    [svn:fx-4.x] 14952: TLF 1.1 Build 597
    Carol L. Frampton Level 2
      Revision: 14952
      Revision: 14952
      Author:   cframpto@adobe.com
      Date:     2010-03-23 13:11:19 -0700 (Tue, 23 Mar 2010)
      Log Message:
      TLF 1.1 Build 597
      • Performance work - major changes to improve performance in long documents
      • Fix 2568628 assigned SWFContext not used on Argo in all scenarios
      • Fix 2568438 TextLineRecycler change for Build543 increased size of Flex's Hello World app using FTE and TextLineRecycler by 250k
      • Fix 2571205 TLF: src attribute in <img> tag converts to lower case when using TextConverter.importToFlow with TEXT_FIELD_HTML_FORMAT format
      • Fix 2582917 Security sandbox violation in LinkElement.stageMouseMoveHandler
      • Fix 2565658 Security sandbox violation in ContainerController.getContainerController
      • Fix 2565639 Security sandbox violation in SelectionManager.checkForDisplayed()
      QE notes: 1 failure gumbo/components/ComboBox/Styles/ComboBox_Styles ComboBox_Styles_lineThrough
      Doc notes: None
      Bugs:
      Reviewed By: Hans
      Tests run: checkintests, TextArea, TextInput, ComboBox, Label, RichText
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25693
          http://bugs.adobe.com/jira/browse/SDK-25734
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/air-config.xml
          flex/sdk/branches/4.x/frameworks/flex-config.xml
          flex/sdk/branches/4.x/frameworks/libs/textLayout.swc
          flex/sdk/branches/4.x/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/branches/4.x/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout .compose.xml
          flex/sdk/branches/4.x/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout .container.xml
          flex/sdk/branches/4.x/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout .conversion.xml
          flex/sdk/branches/4.x/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout .elements.xml
          flex/sdk/branches/4.x/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout .formats.xml
          flex/sdk/branches/4.x/frameworks/projects/textLayout/bundles/en_US/docs/flashx.undo.xml
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCo mpose.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/compose/Compos eState.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/compose/Simple Compose.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/compose/Standa rdFlowComposer.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFl owLine.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextLi neRecycler.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/container/Cont ainerController.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/container/Text ContainerManager.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/conversion/Htm lImporter.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/conversion/Tex tConverter.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/conversion/Tex tLayoutImporter.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManag er.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClient .as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/edit/Selection Manager.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowE lement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowG roupElement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowL eafElement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/Globa lSettings.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/Inlin eGraphicElement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/LinkE lement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/Parag raphElement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanE lement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/SubPa ragraphGroupElement.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextF low.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/factory/String TextLineFactory.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextFl owTextLineFactory.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextLi neFactoryBase.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITabSt opFormat.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITextL ayoutFormat.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabSto pFormat.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabSto pFormatInc.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLa youtFormat.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLa youtFormatInc.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLa youtFormatValueHolder.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/operations/Ins ertTextOperation.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/property/Prope rty.as
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/undo/UndoManager.as
      Added Paths:
          flex/sdk/branches/4.x/frameworks/projects/textLayout/src/flashx/textLayout/utils/Twips.as
          flex/sdk/branches/4.x/frameworks/rsls/textLayout_1.1.0.597.swf
      Removed Paths:
          flex/sdk/branches/4.x/frameworks/rsls/textLayout_1.0.0.595.swf
