0 Replies Latest reply on Mar 23, 2010 2:34 PM by Jason Szeto
    [svn:fx-trunk] 14963: Merging revisions 14946 and 14947 from 4.x to trunk
    Jason Szeto Level 3
      Revision: 14963
      Revision: 14963
      Author:   jszeto@adobe.com
      Date:     2010-03-23 14:34:04 -0700 (Tue, 23 Mar 2010)
      Log Message:
      Mirroring code hinting fixes
      http://bugs.adobe.com/jira/browse/SDK-25565 - Components should define metadata for  layoutDirection and direction styles
      There is both a style and property called layoutDirection in UIComponent. For UIComponent, both Hans and I agree that we should promote the use of the style. I added an exclude for the layoutDirection property in UIComponent. This allows code hinting for the layoutDirection style in the CSS style declaration. It also removes the layoutDirection property from the ASDoc. Code hinting still works for the layoutDirection attribute on a UIComponent subclass MXML tag. This attribute gets set to the property, not the style.
      ProgressBar has both a direction property and style. However, in this situation, they control different behaviors. It is not possible to code hint for the direction style in the CSS style declaration without removing the direction property from ASDoc. We are just going to have to live with this limitation.
      http://bugs.adobe.com/jira/browse/SDK-25823 - The layoutDirection style/property doesnt code hint static enums
      Added Inspectable metadata to BitmapAsset, SpriteAsset, SpriteVisualElement and GraphicElement.
      QE notes: test code hinting for layoutDirection
      Doc notes: none
      Bugs: SDK-25565, SDK-25823
      Reviewer: Carol, Hans
      Tests run: checkintests, Mirroring
      Is noteworthy for integration: no
      ColorPicker and PopUpButton mirroring bug fix
      http://bugs.adobe.com/jira/browse/SDK-25916 - color/label field in swatch panel isn't updated when layoutDirection is
      changed between rtl and ltr
      Since the ColorPicker's SwatchPanel is parented by the SystemManager it wasn't inheriting the layoutDirection and it wasn't invalidating the layoutDirection. The fix is to pass the layoutDirection to the SwatchPanel and always call invalidateLayoutDirection in PopUpManager.addPopUp.
      http://bugs.adobe.com/jira/browse/SDK-25828 - initial popup starts with wrong position, not aligned with PopupButton when there is padding set on container
      The popup is not guaranteed to know its size until it has been added as a popup. Moved the position logic to after the popup has been added.
      QE notes: test mirrored ColorPicker and PopUpButton
      Doc notes: none
      Bugs: SDK-25916
      Reviewer: Carol
      Tests run: checkintests, ColorPicker, PopUpButton
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/PopUpButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/BitmapAsset.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/SpriteAsset.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
      Property Changed:
          flex/sdk/trunk/
