6 Replies Latest reply on Mar 24, 2010 5:18 AM by Ned Murphy
    Javascript help please...
    dan hop Level 1
      The following code just doesn't work.
      Can't figure out why...
      Please advise.
      Dan H
      Version:1.0 StartHTML:0000000105 EndHTML:0000007480 StartFragment:0000002314 EndFragment:0000007444
      <HEAD>
      <SCRIPT type="text/javascript">
      Function ValidateForm(true_false)
      if(inputform.name.value== "")
                  {alert("You forgot to enter your name. \n Please do so now.");
                  inputform.name.focus();
                  return false;}
      else if(inputform.comment.value== "")
                  {alert("Oops... You forgot to tell us your 'Comments'\n Just place your cursor in the 'Comments' area and tell us your thoughts.");
                  inputform.comment.focus();
                  return false;}
      else if(inputform.name.topic== "")
                  {alert("Please enter the SUBJECT of your comments.");
                  inputform.topic.focus();
                  return false;}
      else if(inputform.email.value== "")
                  {alert("Please enter your email address so we can reply to your note.");
                  inputform.email.focus();
                  return false;}
      else
      {return true;}
      </SCRIPT>
      </HEAD
      <BODY>
      <FORM name="inputform"
                              id="inputform"
                              method="post"
                              action="formmailer.php"
                              onSubmit="return ValidateForm(this);" >
      </BODY>
        • 1. Re: Javascript help please...
          Just eyeballing the js, this line appears to be off...
          If this doesn't fix it, if you could post the entire form it would make it easier to troubleshoot.  Both halves of the equation need to be seen
          • 2. Re: Javascript help please...
            dan hop Level 1
            The form is at:
            http://www.hoppernet.info/ynot/talk.php
            Thx for replying
            dan h
            • 3. Re: Javascript help please...
              Did you fix that line to see if it fixed the problem?  I still see it in the page.
              One other thing I notice...  "Function" should be "function"
              • 4. Re: Javascript help please...
                Based on what I see and what I don't see, the following revision of the js code should work...
                function ValidateForm(true_false)
                     if (document.inputform.name.value== "")
                          document.inputform.name.focus();
                          return false;
                     else if (document.inputform.comment.value== "")
                          document.inputform.comment.focus();
                          return false;
                     else if (document.inputform.topic.value== "")
                          document.inputform.topic.focus();
                          return false;
                     else if (document.inputform.email.value== "")
                          document.inputform.email.focus();
                          return false;
                     else
                          return true;
                </SCRIPT>
                • 5. Re: Javascript help please...
                  dan hop Level 1
                  Thanks a ton...
                  lower case 'function'
                  'document.' before the 'inputform'
                  removed the extra text from the 'topic'
                  Seems to have done the trick!
                  JavaScript is just SOooooo nit-picky - and indispensable...
                  I have a bit of tidying up to do but I marked this problem as 'solved'.
                  Thanks again Ned.
                  dan H.
                  • 6. Re: Javascript help please...
                    You're welcome Dan.  Any type of programming is nit-picky.
