This content has been marked as final.
Show 14 replies
1. Re: Master Detail Pages
Newsgroup_User Sep 13, 2007 4:19 AM (in response to oicram)"oicram" <webforumsuser@macromedia.com> wrote in message
news:fcb531$c7g$1@forums.macromedia.com...
> mySQL, php, Dreamweaver, ADDT
> I'm studing different possibilities for a Master Detail Page Approach:
> How can we have a Master Detail page in the SAME page?
Using 2 recordsets, one for the master (all records), one for the detail (1
record)
> IF and only if, the last solution cannot be done, we can have the Detail
> Page
> in a popup. But when we close the popup without (after editing the
> details) how
> can we refresh the parent window, so the new data can be updated?
Haven't used that method for years (hate popups), not sure if it still works
in current browsers;
with javascript you can access the "opener" of the window
window.opener.location.reload(true);
> Is there a way to make a Master Detail in the same page using show/hide
> properties, so when the user clicks on show more details the details will
> appear. (using spry maybe?)
Sure, look at this document:
Spry basic master and detail region overview and structure
http://livedocs.adobe.com/en_US/Spry/1.4/WS9F9E1959-1FDF-4fa3-A9AC-20E928E07ED1.html
> Thanks in advance
You're welcome
Joris
2. Re: Master Detail Pages
oicram Sep 13, 2007 6:25 AM (in response to oicram)>Using 2 recordsets, one for the master (all records), one for the detail (1
record)
Can you explain a little more please, what happens next?
But that does not imply that I should leave my Recorset and move to a Spry Data set? And that not implys also that I need to have a filter / search also using Spry components?
Cas I have a traditional recorset but I only want to apply a show/hide with some possible effects from Spry...
Thanks in advance again, ;)
3. Re: Master Detail Pages
Newsgroup_User Sep 13, 2007 9:04 AM (in response to oicram)
news:fcbdnq$ld2$1@forums.macromedia.com...
> >(1
> record)
You apply a Go to Detail Page serverbehavior to the content from the Master
(list) recordset, then you filter the second recordset with the parameter
from the Go to Detail Page serverbehavior, and apply a "Show if recordset
not empty" to the Detail content
> Data set?
No it doesn't, but you can do master/Detail with Spry
>And that not implys also that I need to have a filter / search also > using
>Spry components?
You could, but again you don't have to,
> with
Sure you can, sorry I missed the part "IF and only if, the last solution
cannot be done" and answered anyway.
Joris
4. Re: Master Detail Pages
oicram Sep 13, 2007 9:56 AM (in response to oicram)Thanks.
You are giving me hope. :)
But the link that you have give me talks only in Datasets. I don't have any.
Where can I found similar information regarding Recordsets? And the work between them?
I have know an extension that translates a Recorset into XML, and HAND ways to do this. But I don't want to translate to XML. I only want to use spry effects (like show hide) to "play" with my dynamic information bring by the recorset.
I.E. Spry Effects inside a repeat region. Problem: I get only the first record of the repeat region to work.
So I think, for now, that they are not friends. And I have no idea if I can make them friends.
Thanks for your time once again, hope you can clarify something here. -
5. Re: Master Detail Pages
Newsgroup_User Sep 13, 2007 11:51 AM (in response to oicram)"oicram" <webforumsuser@macromedia.com> wrote in message
news:fcbq4m$5t3$1@forums.macromedia.com...
> Thanks.
> any.
That link assumed you wanted to do it all in spry
> between them?
There is no info about creating recordset based master/detail functionality
in a single page, dreamweaver manuals assume that "master" and "detail" are
separate pages, the process remains the same with the exception of creating
a separate detail page.
> ways to
> effects
> recorset.
> record
It probably has something to do with the code, javascripts tend to use id's
to reference objects in the page, and id's should be unique, so when
repeating content that has id's that are referenced my javascripts you
should make sure you make sure those id's are in fact unique.
> can
> make them friends.
It may be better to repost the spry part of your question in the SPRY group
news://forums.macromedia.com/macromedia.labs.spry_framework_for_ajax_prerelease
please include code as seen by your browser (view source) because spry only
operates on the client-side.
I think the main confusion is between server-side and client-side code, the
PHP/ASP etc code runs on your webserver and produces HTML output, that code
is never seen or executed by your browser, the javascript (spry) on the
other hand runs only in your browser, not on the server.
Joris
6. Re: Master Detail Pages
oicram Sep 13, 2007 2:48 PM (in response to oicram)>You apply a Go to Detail Page serverbehavior to the content from the Master
Perfect. Thanks. The only problem with this approach is the use of back button, how can we allow the use of the back button in cases like this?
Thanks. -
7. Re: Master Detail Pages
Newsgroup_User Sep 13, 2007 3:00 PM (in response to oicram)"oicram" <webforumsuser@macromedia.com> wrote in message
news:fccb8e$o0r$1@forums.macromedia.com...
> >Master
> Thanks.
Well.... you don't, as you're not actually navigating to another page, just
showing and hiding certains regions in the same page. That's why the
standard master-detail functionality uses two separate pages.
However you can eliminate the javascript/div approach and use a second
recordset to display the detail data filtered by an id that you pass via the
"Go to detail page" server behavior as I originally suggested.
follow the steps outlined in
Building master and detail pages (all servers)
http://livedocs.adobe.com/en_US/Dreamweaver/9.0/help.html?content=WSc78c5058ca073340dcda91 10b1f693f21-79e0.html
but make your master page and detail page the same.
Joris
8. Re: Master Detail Pages
oicram Sep 14, 2007 1:44 AM (in response to oicram)Joris, I have two versions, Sorry for the miss confusion.
In the other post, I'm using another approach and I don't need to use the back button in there as its obvious (I think) for the user that he must click on show/hide and not (go back).
In this post, I'm using this approach:
"the javascript/div approach and use a second
"Go to detail page" server behavior as I originally suggested."
And is in this aproach that I'm asking for a functional backbutton.
Now I get an error page in IE saying:
"Webpage has expired
Most likely cause:
The local copy of this webpage is out of date, and the website requires that you download it again. ..."
and Firefox a warning window.
The page you are trying to view contains POSTDATA that has expired from cache.
If you resend the data, any action the form carried out will be repeated.
To resend the data, click, OK. Otherwise, click Cancel.
Sorry again, and thanks again for your help. -
9. Re: Master Detail Pages
Newsgroup_User Sep 14, 2007 2:55 AM (in response to oicram)"oicram" <webforumsuser@macromedia.com> wrote in message
news:fcdhlj$4os$1@forums.macromedia.com...
> back
> on
> the
> Most likely cause:
> that
> cache.
This is the result of using post variables, since these variables aren't
contained in the url, newer browsers try to warn you before resubmitting.
Using the GET method the sorm-elements will be encoded in the url and that
url can be saved in history. So try switching your form to method
get/default and replacing all $_POST with $_GET.
Joris
10. Master Detail Pages
oicram Sep 14, 2007 3:08 AM (in response to oicram)Was last question and then I close this threat with your answer, is not more secure to use $_POST instead of $_GET or its a mith?
thanks -
11. Re: Master Detail Pages
Newsgroup_User Sep 14, 2007 3:21 AM (in response to oicram)"oicram" <webforumsuser@macromedia.com> wrote in message
news:fcdmim$9oi$1@forums.macromedia.com...
> Was last question and then I close this treat with your answer, is not
> thanks
It's a myth, it may seem a little more difficult to craft a tailored
malicious request than changing some parameters in the address bar but in
reality it isn't.
You should never rely on user input for critical variables, do not use
hidden form fields for things like the user_id in a session variable,
because they will be able to change it.
NEVER try to do security trough obscurity
http://en.wikipedia.org/wiki/Security_through_obscurity
13. Re: Master Detail Pages
oicram Sep 14, 2007 7:51 AM (in response to oicram)I think I shoud have a new post, but once this question is related is better to do it here.
To have the possibility of using the back browser button, I have change all the methods here to $_GET but I cannot get the detail page to work :S
Here is the link:
http://www.cantinho.org/admin/cantinho/encontrar_animal_5.php
This is a case to say: "I don't GET it" :s
Thanks. -
14. Re: Master Detail Pages
oicram Sep 14, 2007 7:59 AM (in response to oicram)in the go to detail page
I have UNCHECK the checkbox with the option:
Pass existing parameters: URL parameters.
And I have CHECKED the checkbox with the option:
FORM parameters.
It works.
I solve one!!! YEAH! :D
Sorry for the joke, I have a special way of doing not funny jokes. :)
