2 Replies Latest reply on Mar 24, 2010 4:12 PM by NikolaV97
    Sound Functions on button presses
    xcmuddman Level 1
      Hi All,
      i will be adding some sound "beeps" (most likely 2 second  audibles) that will play when a user hits a button etc.
      is it better to have them load/play by delegating a button press to them?
      I am concerned about how the timeline can get bogged down and i want them to play only when prompted by a button press for a certain amount of time (eg. 2seconds etc.)  --- not governed by the timeline...
      Also if the user moves  backward on the timeline i wont want the sound to play... so more like  when they press a button i will need it to play...
      do you have  any suggestions on this?
        • 1. Re: Sound Functions on button presses
          add the sound to your library, assign a linkage id and use the sound class to attach your sound.  play it when your button is clicked.
          • 2. Re: Sound Functions on button presses
            as i understood you want to play a beep when you press a button...
            if im right, do the following:
            - add the sound to your library
            - make a button, or use a premade one...
            - double click on the button to edit it
            - so now you should see 4 frames: Up(when button does nothing, just stands), Over(when you go over the button with the pointer), Down(when you click it), Hit(clicked)
            - i guess the best would be to put the sound in 'Down' frame so it plays when clicked
                          adding the sound - just drag and drop the sound from library to frame 3...
            i hope i helped, if not reply me and ill try to explain again...
