whenever I try to run a Flash application which is embedded in a PDF (within a Rich Media Annotation) and which was compiled using Flex 4, Adobe Reader 9.3.1 issues three security warnings:
If I allow all of them, the Flash content enters a never-ending initialization loop. With Flex 3 this never happend. Flex 3 generated Flash applications ran moothly without any security warning at the beginning. Here are two sample MXML source files, one to be compiled with Flex-3 and another to be compiled with Flex-4:
<?xml version="1.0"?> <!-- hello3.mxml --> <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"> <mx:Panel title="My Application" paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10" > <mx:Label text="Hello World!" fontWeight="bold" fontSize="24"/> </mx:Panel> </mx:Application>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:s="library://ns.adobe.com/flex/spark"> <s:layout> <s:VerticalLayout/> </s:layout> <s:Panel title="My Application" paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10" > <s:Label text="Hello World" fontWeight="bold" fontSize="24"/> </s:Panel> </s:Application>
What do I have to do to get rid of the warnings and to get PDF-embedded Flash apps running as they used to do when compiled with Flex 3?
Thanks for your suggestions,
Alexander
PS: the mxmlc option `-use-network=false' doesn't help.
It's the SWZs that are causing the problem. The solution is pretty simple, you can set Flash Builder 4 to compile your project into a single SWF by selecting the Project then Properties -> Flex Build Path -> Library Path and select "Merged into code" from the "Framework linkage" drop down list... now you've got one SWF and no security dialogs.
