7 Replies Latest reply on Mar 24, 2010 12:07 PM by kglad
    Preloader Adjustment
    kitster79 Level 1
      Hello,
      I just launched my new website (I am a graphic designer) and I used a pre-existing flash pre-loader on my home page that was created for me from another project. The loading bar used to be shorter but I stretched it out to be wider. The problem is that now the actual progress bar does not go all the way across to 100%. I’m pretty sure it’s just a number change that needs to be done somewhere in the code – I just don’t know where.
      If at all possible I would greatly appreciate it if you could point me in the right direction:)
      Here is the pre-loader I’m talking about – http://www.vojodesign.com
      Here is my script:
      import fl.transitions.TweenEvent;
      import flash.utils.getDefinitionByName;
      import flash.events.Event;
      import flash.net.navigateToURL;
      import flash.net.URLRequest;
      var links_list:Array=["index.php?option=com_content&view=article&id=37&Itemid=14",
                            "index.php?option=com_content&view=article&id=38&Itemid=9",
                            "index.php?option=com_content&view=article&id=17&Itemid=10",
                            "index.php?option=com_content&view=article&id=37&Itemid=11"];
      this.StartPreloading();
      function StartPreloading(){
          this.addEventListener(Event.ENTER_FRAME,this.onPreloaderEnterFrame);
          this.SetProgress(0);
      function onPreloaderEnterFrame(ev:Event){
          var clip_total=this.loaderInfo.bytesTotal;
          var clip_loaded=this.loaderInfo.bytesLoaded;
          var clip_progr=clip_loaded/clip_total;
          var progr=clip_progr;
          this.SetProgress(progr);
          if(progr>=1){
              this.removeEventListener(Event.ENTER_FRAME,this.onPreloaderEnterFrame);
              this.gotoAndPlay("go");
      function SetProgress(val:Number){
          this.Preloader_mc.Text_txt.text=Math.round(val*100);
          this.Preloader_mc.Bar_mc.Progress_mc.Line_mc.scaleX=val;
      var current_tab:int=0;
      var current_slide=null;
      function SetupButtons(){
          for(var i=0;i<5;i++){
              var button=this.Buttons_mc.getChildByName("bn"+i);
              button.AddListener(String(i),this.onMenuButton);
              if(i==this.current_tab) button.is_selected=true;
      function onMenuButton(cmd:String){
          var button=this.Buttons_mc.getChildByName("bn"+this.current_tab);
          button.is_selected=false;
          button=this.Buttons_mc.getChildByName("bn"+cmd);
          this.current_tab=int(cmd);
          this.SwitchToSlide();
      function SwitchToSlide(){
          var class_ref:Class=getDefinitionByName("slide"+String(this.current_tab)) as Class;
          var slide=new class_ref();
          slide.predecessor=this.current_slide;
          if(this.current_tab>0){
              slide.link=this.links_list[this.current_tab-1];
          this.addChild(slide);
          this.current_slide=slide;
          this.current_slide.Reveal();
      function onSlideShown(ev:TweenEvent){
      Thanks in advance.
        • 1. Re: Preloader Adjustment
          is the line of code that's causing the problem.  you were scaling that movieclip to 1 (or full width).  after you made your changes, full width is less than you want.
          to remedy, IF that movieclip starts full-width, you could store the full width of that movieclip using:
          var Line_mcW:Number = this.Preloader_mc.Bar_mc.Progress_mc.Line_mc.width;
          and use:
          this.Preloader_mc.Bar_mc.Progress_mc.Line_mc.width=val*Line_mcW;
          • 2. Re: Preloader Adjustment
            kitster79 Level 1
            Thanks for your swift response. So I swapped this...
            for this...
            Is that what you meant?  The preloader dosnt do anything now:(
            • 3. Re: Preloader Adjustment
              that won't work, as you know.
              try:
              var Line_mcW:Number=this.Preloader_mc.Bar_mc.Progress_mc.Line_mc.width;
              trace(Line_mcW):  // if this is zero, you'll need to change the above line of code
                  if(progr>=1){
              • 4. Re: Preloader Adjustment
                kitster79 Level 1
                This is what came up in the error panel:
                script.as, Line 16
                1078: Label must be a simple identifier.
                • 5. Re: Preloader Adjustment
                  that should be a semi-colon, not a colon.
                  • 6. Re: Preloader Adjustment
                    kitster79 Level 1
                    It works perfectly!  Thank you for your help kglad:)
                    • 7. Re: Preloader Adjustment
                      you're welcome.
                      p.s.  please mark this thread as answered, if you can.
