13 Replies Latest reply on Apr 12, 2010 12:52 AM by reinoud-jules
    Flash Builder 4 == No code hinting?
    flairjax Level 1
      So I have no code hinting on my FB4 Premium version on my MAC OSX 10.5? Anyone else have this issue?
        • 1. Re: Flash Builder 4 == No code hinting?
          flairjax Level 1
          Also holding down the control key and mouse over skins references doesn't show the underline or allow you to click it to go to the source.
          • 2. Re: Flash Builder 4 == No code hinting?
            Jason San Jose Adobe Employee
            Sounds like some SWCs aren't being read. What SDK are you using and were there any modifications made to it?
            Jason San Jose
            Software Engineer, Flash Builder
            • 3. Re: Flash Builder 4 == No code hinting?
              flairjax Level 1
              Also, you can't click a component ref mx:Button or cm:CustomButton to go to the source?
              • 4. Re: Flash Builder 4 == No code hinting?
                Larry McLister (Adobe) Adobe Employee
                Hi Dallas
                It sounds very much like you are using a beta workspace.  Can you try the following?
                  1. Choose File > Switch Workspace > Other and then select a new workspace location
                  2. Create a new Flex project
                  3. Try to get code hints
                  4. If that works, choose File > Switch Workspace and go back to your original workspace
                  5. Export you project(s) via File > Export Flex Project
                  6. Choose File > Switch Workspace > Other and then select the new  workspace location
                  7. Choose File > Import Flex Project and import your projects.
                If this does not work, please post a code sample and more information about your configuration.
                -Larry
                • 5. Re: Flash Builder 4 == No code hinting?
                  flairjax Level 1
                  I am using the swc's that came with FB4 Premium plus some a couple open source swcs.  Tried switching workspaces but no go.
                  • 6. Re: Flash Builder 4 == No code hinting?
                    By "a couple open source swcs", what exactly did you do? Did you drop them into your project or into the SDK frameworks/libs folder?
                    Is there anything in your error log?
                    Win: c:\users\you\Adobe Flash Builder 4\.metadata\.log
                    Mac: /users/you/documents/AdobE Flash Builder 4/.metadata/.log
                    Jason San Jose
                    • 7. Re: Flash Builder 4 == No code hinting?
                      flairjax Level 1
                      So just to be sure I removed my sdk references and added the 4.0.0 again.
                      Now it says "unknown configuration variable 'compiler.omit-trace-statements'
                      • 8. Re: Flash Builder 4 == No code hinting?
                        flairjax Level 1
                        added them via project > properties > Flex Build Path > Add
                        I fixed this both issues.  I just deleted my project without deleting the source code and switched back to my orig. workspace and imported my project again and it works.
                        • 9. Re: Flash Builder 4 == No code hinting?
                          That's great, but I'm still curious to know what failed. If there's anything in your error log, please let us know.
                          Another user found an issue with malformed metadata in a SWC that would cause code hints to fail http://bugs.adobe.com/jira/browse/FB-26363.
                          There could be other issues in those SWCs that haven't been reported. If you have the time, please help us out with more information and I'll be happy to file the bug on your behalf.
                          Jason San Jose
                          • 10. Re: Flash Builder 4 == No code hinting?
                            flairjax Level 1
                            !SESSION 2010-03-24 13:31:15.865 -----------------------------------------------
                            eclipse.buildId=unknown
                            java.version=1.5.0_22
                            java.vendor=Apple Inc.
                            BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
                            Framework arguments:  -keyring /Users/jason_bigdog/.eclipse_keyring -showlocation
                            Command-line arguments:  -os macosx -ws carbon -arch x86 -data /Users/jason_bigdog/work/Adobe Flash Builder 4 -keyring /Users/jason_bigdog/.eclipse_keyring -consoleLog -showlocation
                            !ENTRY org.eclipse.core.net 1 0 2010-03-24 13:31:23.016
                            !MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
                            !SESSION 2010-03-24 13:33:59.153 -----------------------------------------------
                            !ENTRY org.eclipse.core.net 1 0 2010-03-24 13:34:06.192
                            !ENTRY com.adobe.flexbuilder.dcrad 4 1 2010-03-24 13:34:57.866
                            !MESSAGE Unable to load services because the fml file is invalid. See error log for more details.
                            !STACK 0
                            java.lang.Throwable: ERROR /Users/jason_bigdog/work/My_Project/.model/My_Project.fml: XML parse error : Error on line 3 of document  : cvc-elt.1: Cannot find the declaration of element 'model'. Nested exception: cvc-elt.1: Cannot find the declaration of element 'model'.
                                at com.adobe.flexbuilder.dcrad.core.generation.ServicesGenerator.generate(ServicesGenerator. java:73)
                                at com.adobe.flexbuilder.dcrad.core.generation.ServicesGenerationManager.loadProjectServices (ServicesGenerationManager.java:72)
                                at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager$ServiceExplorerPartListener.<in it>(ServicesManager.java:1235)
                                at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager.addListeners(ServicesManager.ja va:302)
                                at com.adobe.flexbuilder.dcrad.core.internal.ServicesManager.getInstance(ServicesManager.jav a:344)
                                at com.adobe.flexbuilder.dcrad.datamodel.DcdFxpContributor.getContributors(DcdFxpContributor .java:195)
                                at com.adobe.flexbuilder.dcrad.datamodel.DcdFxpContributor.notifyImportSuccess(DcdFxpContrib utor.java:60)
                                at com.adobe.flexbuilder.exportimport.importwizard.ImportWizard.notifyImportSuccess(ImportWi zard.java:408)
                                at com.adobe.flexbuilder.exportimport.importwizard.ImportWizard.performFinish(ImportWizard.j ava:133)
                                at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:752)
                                at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:373)
                                at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
                                at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
                                at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1598)
                                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1622)
                                at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1607)
                                at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1396)
                                at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3484)
                                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3068)
                                at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
                                at org.eclipse.jface.window.Window.open(Window.java:801)
                                at org.eclipse.ui.internal.handlers.WizardHandler$Import.executeHandler(WizardHandler.java:1 46)
                                at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:273)
                                at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:294)
                                at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
                                at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.jav a:508)
                                at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
                                at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.j ava:241)
                                at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
                                at org.eclipse.ui.internal.actions.CommandAction.run(CommandAction.java:171)
                                at org.eclipse.ui.actions.ImportResourcesAction.run(ImportResourcesAction.java:97)
                                at org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEvent(BaseSelectionListenerActi on.java:168)
                                at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:584)
                                at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
                                at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
                                at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
                                at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
                                at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
                                at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
                                at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
                                at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
                                at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                                at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :109)
                                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
                                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
                                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                                at java.lang.reflect.Method.invoke(Method.java:592)
                                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
                                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
                                at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
                            !ENTRY com.adobe.flexbuilder.DCDService 4 1 2010-03-24 13:34:57.907
                            !MESSAGE Invalid fml file. Unable to load services. Reason: ERROR /Users/jason_bigdog/work/My_Project/.model/My_Project.fml: XML parse error : Error on line 3 of document  : cvc-elt.1: Cannot find the declaration of element 'model'. Nested exception: cvc-elt.1: Cannot find the declaration of element 'model'.
                            !STACK 0
                            java.io.IOException: Invalid fml file. Unable to load services. Reason: ERROR /Users/jason_bigdog/work/My_Project/.model/My_Project.fml: XML parse error : Error on line 3 of document  : cvc-elt.1: Cannot find the declaration of element 'model'. Nested exception: cvc-elt.1: Cannot find the declaration of element 'model'.
                                at com.adobe.flexbuilder.DCDService.core.persistence.DataServicePersistenceManager.loadModel (DataServicePersistenceManager.java:377)
                                at com.adobe.flexbuilder.dcrad.utils.DCRADUtility.getDataModelName(DCRADUtility.java:1569)
                                at com.adobe.flexbuilder.dcrad.utils.DCRADUtility.getServerConfiguration(DCRADUtility.java:1 382)
                                at com.adobe.flexbuilder.dcrad.datamodel.DataModelUpdater.updateDataModel(DataModelUpdater.j ava:75)
                                at com.adobe.flexbuilder.dcrad.datamodel.DataModelUpdater.serverSettingsChanged(DataModelUpd ater.java:144)
                                at com.adobe.flexbuilder.dcrad.datamodel.DcdFxpContributor.notifyImportSuccess(DcdFxpContrib utor.java:65)
                            !ENTRY com.adobe.flexbuilder.DCDService 4 1 2010-03-24 13:34:57.911
                            !STACK 0
                                at com.adobe.flexbuilder.dcrad.datamodel.DataModelUpdater.validate(DataModelUpdater.java:107 )
                                at com.adobe.flexbuilder.dcrad.datamodel.DataModelUpdater.updateDataModel(DataModelUpdater.j ava:89)
                            !ENTRY com.adobe.flexbuilder.project 4 43 2010-03-24 13:34:59.320
                            !MESSAGE Could not traverse changed resources in project My_Project.
                            !STACK 1
                            org.eclipse.core.internal.resources.ResourceException: Resource '/My_Project/${PROJECT_FRAMEWORKS}/javascript/fabridge/samples/fabridge/javascript' does not exist.
                                at org.eclipse.core.internal.resources.Resource.checkExists(Resource.java:319)
                                at org.eclipse.core.internal.resources.Resource.checkAccessible(Resource.java:196)
                                at org.eclipse.core.internal.resources.Resource.accept(Resource.java:49)
                                at org.eclipse.core.internal.resources.Resource.accept(Resource.java:106)
                                at org.eclipse.core.internal.resources.Resource.accept(Resource.java:90)
                                at com.adobe.flexbuilder.project.compiler.internal.BuilderUtils.copyDependents(BuilderUtils. java:359)
                                at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.build(FlexProjectBuild er.java:346)
                                at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilder.build(FlexIncremen talBuilder.java:157)
                                at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:627)
                                at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:170)
                                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:201)
                                at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:253)
                                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:256)
                                at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:309)
                                at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:341)
                                at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:140)
                                at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:238)
                                at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
                            !SUBENTRY 1 org.eclipse.core.resources 4 368 2010-03-24 13:34:59.321
                            !MESSAGE Resource '/My_Project/${PROJECT_FRAMEWORKS}/javascript/fabridge/samples/fabridge/javascript' does not exist.
                            !ENTRY com.adobe.flexbuilder.project 4 43 2010-03-24 13:35:47.208
                            !MESSAGE Could not load current project.
                            !STACK 0
                            java.lang.reflect.InvocationTargetException
                                at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
                                at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
                                at com.adobe.flexide.editorcore.loadservice.CodeModelProjectLoadDialog.runLoadProject(CodeMo delProjectLoadDialog.java:188)
                                at com.adobe.flexide.editorcore.loadservice.DefaultCMLoadService.loadProject(DefaultCMLoadSe rvice.java:52)
                                at com.adobe.flexide.editorcore.loadservice.DefaultCMLoadService.loadProject(DefaultCMLoadSe rvice.java:71)
                                at com.adobe.flexide.editorcore.editor.AbstractFlexDocumentProvider.connect(AbstractFlexDocu mentProvider.java:106)
                                at com.adobe.flexbuilder.mxml.editor.code.MXMLDocumentProvider.connect(MXMLDocumentProvider. java:65)
                                at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4134)
                                at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:203)
                                at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEdi tor.java:1413)
                                at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:166)
                                at com.adobe.flexide.editorcore.editor.AbstractFlexEditor.doSetInput(AbstractFlexEditor.java :1422)
                                at org.eclipse.ui.texteditor.AbstractTextEditor$19.run(AbstractTextEditor.java:3115)
                                at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
                                at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
                                at org.eclipse.jface.window.ApplicationWindow$1.run(ApplicationWindow.java:759)
                                at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
                                at org.eclipse.jface.window.ApplicationWindow.run(ApplicationWindow.java:756)
                                at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2579)
                                at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3133)
                                at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3160)
                                at com.adobe.flexide.editorcore.editor.AbstractFlexEditor.init(AbstractFlexEditor.java:452)
                                at com.adobe.flexide.mxml.core.editor.MXMLCoreEditor.init(MXMLCoreEditor.java:75)
                                at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:238)
                                at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:212)
                                at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor.createPages(CodeAndDesignEdit or.java:209)
                                at com.adobe.flexbuilder.mxml.editor.MXMLEditor.createPages(MXMLEditor.java:217)
                                at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:357)
                                at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
                                at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
                                at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
                                at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:286)
                                at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2857)
                                at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
                                at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
                                at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
                                at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
                                at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
                                at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
                                at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
                                at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
                                at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
                                at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
                                at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:133)
                                at com.adobe.flexbuilder.editors.derived.ui.navigator.FlexMainActionGroup.runDefaultAction(F lexMainActionGroup.java:350)
                                at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:787)
                                at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:499)
                                at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHel per.java:48)
                                at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
                                at org.eclipse.core.runtime.Platform.run(Platform.java:888)
                                at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
                                at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
                                at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
                                at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
                                at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
                                at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
                                at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
                                at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
                                at org.eclipse.swt.widgets.Control.sendTrackEvents(Control.java:3036)
                                at org.eclipse.swt.widgets.Control.kEventControlTrack(Control.java:2116)
                                at org.eclipse.swt.widgets.Widget.controlProc(Widget.java:375)
                                at org.eclipse.swt.widgets.Display.controlProc(Display.java:863)
                                at org.eclipse.swt.internal.carbon.OS.CallNextEventHandler(Native Method)
                                at org.eclipse.swt.widgets.Tree.kEventMouseDown(Tree.java:2653)
                                at org.eclipse.swt.widgets.Widget.mouseProc(Widget.java:1362)
                                at org.eclipse.swt.widgets.Display.mouseProc(Display.java:2930)
                                at org.eclipse.swt.internal.carbon.OS.SendEventToEventTarget(Native Method)
                                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3051)
                            Caused by: java.lang.NullPointerException
                                at com.adobe.flexbuilder.codemodel.definitions.ASDefinitionFilter.matchesPackage(ASDefinitio nFilter.java:983)
                                at com.adobe.flexbuilder.codemodel.definitions.ASDefinitionFilter.matchesAccessRule(ASDefini tionFilter.java:1057)
                                at com.adobe.flexbuilder.codemodel.internal.definitions.SparseDefinitionSet.findDefinition(S parseDefinitionSet.java:65)
                                at com.adobe.flexbuilder.codemodel.internal.definitions.ASScope.findDefinitionByName(ASScope .java:497)
                                at com.adobe.flexbuilder.codemodel.internal.definitions.ASScope.findDefinitionByName(ASScope .java:462)
                                at com.adobe.flexbuilder.codemodel.internal.tree.MemberedNode.getMemberByName(MemberedNode.j ava:93)
                                at com.adobe.flexbuilder.codemodel.internal.tree.MemberedNode.getMemberByName(MemberedNode.j ava:73)
                                at com.adobe.flexbuilder.codemodel.internal.project.DefinitionsGateway$DefinitionSorter.merg eComments(DefinitionsGateway.java:167)
                                at com.adobe.flexbuilder.codemodel.internal.project.DefinitionsGateway$DefinitionSorter.comp are(DefinitionsGateway.java:105)
                                at com.adobe.flexbuilder.codemodel.internal.project.DefinitionsGateway$DefinitionSorter.comp are(DefinitionsGateway.java:1)
                                at java.util.Arrays.mergeSort(Arrays.java:1284)
                                at java.util.Arrays.sort(Arrays.java:1223)
                                at java.util.Collections.sort(Collections.java:159)
                                at com.adobe.flexbuilder.codemodel.internal.project.DefinitionsGateway.addDefinition(Definit ionsGateway.java:307)
                                at com.adobe.flexbuilder.codemodel.internal.project.DefinitionsGateway.afterNodeAdd(Definiti onsGateway.java:256)
                                at com.adobe.flexbuilder.codemodel.internal.project.Project.afterAddNode(Project.java:401)
                                at com.adobe.flexbuilder.codemodel.internal.project.ProjectManager.propagateDefinitions(Proj ectManager.java:751)
                                at com.adobe.flexbuilder.codemodel.internal.project.ProjectManager.preloadASLibrariesAndSour ce(ProjectManager.java:665)
                                at com.adobe.flexbuilder.codemodel.internal.project.EclipseProjectListener.preloadASLibrarie sAndSource(EclipseProjectListener.java:730)
                                at com.adobe.flexbuilder.codemodel.internal.project.EclipseProjectListener.loadProject(Eclip seProjectListener.java:938)
                                at com.adobe.flexbuilder.codemodel.internal.project.EclipseProjectListener.registerProject(E clipseProjectListener.java:1011)
                                at com.adobe.flexbuilder.codemodel.internal.project.EclipseProjectListener.registerProject(E clipseProjectListener.java:807)
                                at com.adobe.flexide.editorcore.loadservice.CodeModelProjectLoadDialog$1.run(CodeModelProjec tLoadDialog.java:194)
                                at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
                            Root exception:
                            !ENTRY org.eclipse.jface 2 0 2010-03-24 13:35:48.219
                            !MESSAGE Keybinding conflicts occurred.  They may interfere with normal accelerator operation.
                            !SUBENTRY 1 org.eclipse.jface 2 0 2010-03-24 13:35:48.219
                            !MESSAGE A conflict occurred for COMMAND+G:
                            Binding(COMMAND+G,
                                ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.declarations.in.wor kspace,Find All Declarations In Workspace,
                                    Category(com.adobe.flexbuilder.editorcore.navigation.category,Navigation,null,true),
                                    ActionHandler(com.adobe.flexbuilder.as.editor.ui.packageexplorer.actions.FlexPackageExplo rerFindAllDeclarationsAction@396747),
                                    ,,true),null),
                                org.eclipse.ui.defaultAcceleratorConfiguration,
                                com.adobe.flexide.editorcore.flexEditorScope,,,system)
                            Binding(COMMAND+G,
                                    ,,true),null),
                                com.adobe.flexbuilder.as.editor.context.packageexplorer,,,system)
                            !SUBENTRY 1 org.eclipse.jface 2 0 2010-03-24 13:35:48.220
                            !MESSAGE A conflict occurred for COMMAND+SHIFT+G:
                            Binding(COMMAND+SHIFT+G,
                                ParameterizedCommand(Command(com.adobe.flexbuilder.as.editor.find.all.references.in.works pace,Find All References In Workspace,
                                    ActionHandler(com.adobe.flexbuilder.as.editor.ui.packageexplorer.actions.FlexPackageExplo rerFindAllReferencesAction@ada93),
                                    ,,true),null),
                                    ,,true),null),
                            !ENTRY org.eclipse.core.resources 4 380 2010-03-24 14:27:54.451
                            !MESSAGE The resource tree is locked for modifications.
                            !ENTRY org.eclipse.core.resources 4 380 2010-03-24 14:27:54.452
                            !ENTRY org.eclipse.core.resources 4 368 2010-03-24 14:27:54.570
                            !MESSAGE Resource '/My_Project/src/My_Project.mxml' does not exist.
                            • 11. Re: Flash Builder 4 == No code hinting?
                              Interesting. If I'm reading this right...
                              • You were trying to import an FXP that was exported from Beta 2
                              • It looks like there were incompatible changes in model files from Beta 2 in your file My_Project/.model/My_Project.fml. I'll verify that internally.
                              • Eventually the project failed to load
                              I'll see if I can find any more info. Did code hints work for you in a default project in the workspace where you hit this bug?
                              Jason San Jose
                              • 12. Re: Flash Builder 4 == No code hinting?
                                flairjax Level 1
                                Yes, they work now.  I didn't try a brand new project I just switched back to my orig workspace and re-imported the project and it worked.
                                • 13. Re: Flash Builder 4 == No code hinting?
                                  reinoud-jules
                                  Hi Dallas
                                  -Larry
                                  This worked for me with Flash Builder 4 Premium, thanks a lot
