0 Replies Latest reply on Mar 25, 2010 12:24 PM by ice1000
    How to Force a Chart to Redraw?
    ice1000
      I have a column chart that uses a label function to format the vertical  axis. I added a button and want the axis (or chart) to redraw when the  button is clicked. Right now, the chart axis renders OK only when  initially added to the view state.
      I use a function that sets various properties after the chart is  initially created. In there, I have tried all these:
      myChart.verticalAxis.dataChanged();
      myChart.validateNow();
      myChart.validateDisplayList();
      myChart.validateProperties();
      myChart.invalidateDisplayList();
      myChart.invalidateProperties();
      But they do not change the axis formatting.
      What am I missing? How do I call the axis format label function?
      The MXML code for the axis is:
      < mx:LinearAxis id="verticalAxis"  labelFunction="vAxisFormat"/>
      The label function is:
          private function vAxisFormat(labelValue:Number, previousValue:Object, axis:IAxis):String {
              axis
      .getLabelEstimate();
      if (_scale == 1){
      return currencyFormatter.format(labelValue/_scale);
      }else {
      return numberFormatter.format(labelValue/_scale);
      I found out some more info that may help some experts out there. The Adobe help has
      the following method for the Formatter class:
      resourcesChanged(): This method is called when a Formatter is constructed, and
      again whenever the ResourceManager dispatches a "change" Event to indicate that
      the localized resources have changed in some way.
      This event will be dispatched when you set the ResourceManager's localeChain
      property, when a resource module has finished loading, and when you call the
      ResourceManager's update() method. Subclasses should override this method and,
      after calling super.resourcesChanged(), do whatever is appropriate in response
      to having new resource values.
      So I inserted this with great expectations:
      resourceManager.update();
      That didn't work so I tried:
      resourceManager.dispatchEvent(new Event("Change"));
      Which also didn't work. Grrrr...
      Anyone have any ideas?
      Message was edited by: ice1000 . Added more info
