0 Replies Latest reply on Mar 24, 2010 5:53 PM by Carol L. Frampton
    [svn:fx-trunk] 15011: Merge changes 14914,14929,14952,14961,14987  from 4. x to trunk.
    Carol L. Frampton Level 2
      Revision: 15011
      Revision: 15011
      Author:   cframpto@adobe.com
      Date:     2010-03-24 17:53:17 -0700 (Wed, 24 Mar 2010)
      Log Message:
      Merge changes 14914,14929,14952,14961,14987  from 4.x to trunk.  Includes TLF1.1 Build 587 and mirroring changes.
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/Window.as
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.compos e.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.contai ner.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.conver sion.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.elemen ts.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.textLayout.format s.xml
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/flashx.undo.xml
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCompose.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/ComposeState. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/SimpleCompose .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/StandardFlowC omposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFlowLine. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextLineRecyc ler.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ContainerCo ntroller.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/HtmlImport er.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/TextConver ter.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/TextLayout Importer.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClient.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowLeafElem ent.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/GlobalSettin gs.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/InlineGraphi cElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/LinkElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ParagraphEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SpanElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/SubParagraph GroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/StringTextLin eFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextFlowTextL ineFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/TextLineFacto ryBase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITabStopForma t.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITextLayoutFo rmat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabStopFormat .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TabStopFormat Inc.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor mat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/InsertText Operation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/Property.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/undo/UndoManager.as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/utils/Twips.as
          flex/sdk/trunk/frameworks/rsls/textLayout_1.1.0.597.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.595.swf
      Property Changed:
          flex/sdk/trunk/
