0 Replies Latest reply on Mar 25, 2010 7:01 AM by chieffan
    File Upload using Flex/ColdFusion.  2044 error
    chieffan Level 1
      I am looking for a little more clarity around the file upload using Flex and Cold Fusion.  When I run this using my server I get Error #2044: Unhandled IOErrorEvent:. text=Error #2038: File I/O Error.
      I did create a regular cfform and had it use my ColdFusion upload form and that worked fine, so I feel good about the upload form. I am starting to think there is a permission error with the Flash Player writing to the folder.  When this is ran, it will show the file being 100% loaded but the complete event is never triggered.  I put alerts to see where it hits and 100 does show at the same time as my error message.  The complete alert never shows.  I also put an alert in my cfm page and it never reaches that page to hit it.  Whether I use an absolute URL or relative path. I have also tried the urlrequestmethod.post and nothing changed.  Thanks in advance.  BTW.  I am using Flex 3.
      This is my mxml file
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:example="com.example.*" horizontalAlign="center" viewSourceURL="srcview/index.html">
      <mx:Script>
      <![CDATA[
      import com.example.FileDownload
      import mx.controls.Label
      import com.example.FileUpload
      </mx:Script>
      <mx:Label id="title" text="File I/O Example" fontSize="24" fontStyle="bold" />
      <mx:Text id="subtitle" text="From Programming ActionScript 3.0, Chapter 22: Networking and communication" width="100%" textAlign="center" fontSize="12" />
      <example:FileDownload
      id="fileDownload" creationComplete="fileDownload.init(downloadProgress, cancelDownload);" />
      <example:FileUpload id="fileUpload" creationComplete="fileUpload.init(uploadProgress, cancelUpload);" />
      <mx:HBox>
      <mx:Panel title="Upload File" paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10">
      <mx:ProgressBar id="uploadProgress" label="" mode="manual" />
      <mx:ControlBar horizontalAlign="right">
      <mx:Button id="startUpload" label="Upload..." click="fileUpload.startUpload();" />
      <mx:Button id="cancelUpload" label="Cancel" click="fileUpload.cancelUpload();" enabled="false" />
      </mx:ControlBar>
      </mx:Panel>
      <mx:Panel title="Download File" paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10">
      <mx:ProgressBar id="downloadProgress" label="" mode="manual" />
      <mx:Button id="startDownload" label="Download..." click="fileDownload.startDownload();" />
      <mx:Button id="cancelDownload" label="Cancel" click="fileDownload.cancelDownload();" enabled="false" />
      </mx:ControlBar>
      </mx:Panel>
      </mx:HBox>
      </mx:Application>
      here is my coldfusion upload script
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      <html xmlns="http://www.w3.org/1999/xhtml">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title>Untitled Document</title>
      </head>
      <body>
      <script>alert('hello')</script>
      <cfset currentPath = getCurrentTemplatePath()>
      <cfset currentDirectory = getDirectoryFromPath(currentPath)>
      <cfoutput>This directory is #currentDirectory#</cfoutput>
      <cffile action="UPLOAD" filefield="Filefield" destination="#currentDirectory#" nameconflict="OVERWRITE"/>
      </body>
      </html>
      here is the package
      package
      com.example {
      import flash.events.*;
      import flash.net.FileReference;
      import flash.net.URLRequest;
      import flash.net.URLRequestMethod;
      import mx.controls.Button;
      import mx.controls.ProgressBar;
      import mx.core.UIComponent;
      import mx.controls.Alert;
      public class FileUpload extends UIComponent {
      // Hard-code the URL of the remote upload script.
      private const UPLOAD_URL:String = "upload_script.cfm";
      private var fr:FileReference;
      // Define reference to the upload ProgressBar component.
      private var pb:ProgressBar;
      // Define reference to the "Cancel" button which will immediately stop the upload in progress.
      private var btn:Button;
      public function FileUpload() {
      * Set references to the components, and add listeners for the SELECT,
      * OPEN, PROGRESS, and COMPLETE events.
      public function init(pb:ProgressBar, btn:Button):void {
      // Set up the references to the progress bar and cancel button, which are passed from the calling script.
      this.pb = pb;
      this.btn = btn;
      fr =
      new FileReference();
      fr.addEventListener(Event.SELECT, selectHandler);
      fr.addEventListener(Event.OPEN, openHandler);
      fr.addEventListener(ProgressEvent.PROGRESS, progressHandler);
      // fr.addEventListener(Event.COMPLETE, completeHandler);
      * Immediately cancel the upload in progress and disable the cancel button.
      public function cancelUpload():void {
      fr.cancel();
      pb.label =
      "UPLOAD CANCELLED";
      btn.enabled =
      false;
      * Launch the browse dialog box which allows the user to select a file to upload to the server.
      public function startUpload():void {
      fr.browse();
      * Begin uploading the file specified in the UPLOAD_URL constant.
      private function selectHandler(event:Event):void {
      var request:URLRequest = new URLRequest(UPLOAD_URL);
      /* request.url = UPLOAD_URL*/
      request.method = URLRequestMethod.POST;
      try
      fr.upload(request);
      catch (error:Error){
      trace
      ("error uploading")
      * When the OPEN event has dispatched, change the progress bar's label
      * and enable the "Cancel" button, which allows the user to abort the
      * upload operation.
      private function openHandler(event:Event):void {
      pb.label =
      "UPLOADING";
      btn.enabled =
      true;
      * While the file is uploading, update the progress bar's status and label.
      private function progressHandler(event:ProgressEvent):void {
      pb.label =
      "UPLOADING %3%%";
      pb.setProgress(event.bytesLoaded, event.bytesTotal);
      if(event.bytesLoaded==event.bytesTotal){
      trace(Event.COMPLETE)
      Alert.show(
      "100")
      * Once the upload has completed, change the progress bar's label and
      * disable the "Cancel" button since the upload is already completed.
      private function completeHandler(event:Event):void {
      Alert.show(
      "in function")
      pb.label =
      "UPLOADING COMPLETE";
      pb.setProgress(0, 100);
      btn.enabled =
      false;
