12 Replies Latest reply on Mar 25, 2010 11:31 PM by Harbs.
    Issues with export/save text file from Indesign
    Thomas B. Nielsen Level 3
      Hi scripters,
      I have a problem that i do not know how to solve.
      Indesign CS3, Mac and PC - only seen the problem on some macs, not all, but some always have/get this error.
      I made a script that collects text from selected textframes:
      for (var i = 0; i < myMainList.length; i++) {
      var curTF = myMainList[i];
      while (curTF != null) {
      myExportString += curTF.contents;
      curTF = curTF.nextTextFrame;
      myExportString += "\n\n###############################\n\n";
      alert(myExportString);
      This collects the text and also it will display ok in the dialog.
      However on some computers (macs) the following will only produce a zero byte file (when there is more than one textframe in the loop above, a zero byte file is always produced - but again it's only on some macs) If a single textFrame with only a small amount of text is saved/exported it works:
      var myFolder = Folder.myDocuments.path + "/Desktop/Export";
      //alert("Myfolder: " + myFolder);
      if(!myFolder.exists) {
      Folder(myFolder).create();
      var myFileName = myFolder + "/" +win.FilePnl.FileGrp.FileName.text + ".txt";
      var myFile = new File (myFileName);
      myFile.encoding = 'text';
      myFile.open ("w");
      myFile.write (myExportText.replace("/\u2011/g",'-'));//replace(/[^a-zA-Z 0-9]+/g,''));
      myFile.close();
      Has this got to do with using .contents?
      I hope someone can help me with this, been working on this problem for way to long now.
      Thomas
