0 Replies Latest reply on Mar 25, 2010 11:49 AM by Carol L. Frampton
    [svn:fx-4.x] 15030: AIR Spark Window bugs when layoutDirection="rtl".
    Carol L. Frampton Level 2
      Revision: 15030
      Revision: 15030
      Author:   cframpto@adobe.com
      Date:     2010-03-25 11:49:00 -0700 (Thu, 25 Mar 2010)
      Log Message:
      AIR Spark Window bugs when layoutDirection="rtl".  On Windows only, an empty window when created, didn't maximize or resize correctly.  This class maintains its width/height in bounds rather than in the super class' _width and _height variables.  Need to call setActualSize() whenever bounds is set so that the layoutWidth gets set correctly if this component is mirroring.
      Fix an RTE in TitleWindow that I stumbled upon.  Can not access the nativeWindow displayState if the window is closed.
      QE notes:
      Doc notes: None
      Bugs: SDK-25978, SDK-25827, SDK-25825
      Reviewed By: Jason
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25978
          http://bugs.adobe.com/jira/browse/SDK-25827
          http://bugs.adobe.com/jira/browse/SDK-25825
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/airspark/src/spark/components/Window.as
          flex/sdk/branches/4.x/frameworks/projects/airspark/src/spark/components/windowClasses/Tit leBar.as
