0 Replies Latest reply on Mar 25, 2010 5:15 PM by Jason Szeto
    [svn:fx-4.x] 15044: Mirroring Window Gripper and DateField bug fixes
    Jason Szeto Level 3
      Revision: 15044
      Revision: 15044
      Author:   jszeto@adobe.com
      Date:     2010-03-25 17:15:30 -0700 (Thu, 25 Mar 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-25719 - The gripper does not show up in an MX Window that is mirrored and using flex chrome
      Added an mx_internal property to Button to track if the Button should modify the layoutDirection of its skins. MX Window and MX WindowedApplication both set this property to undefined. This is the only skin/icon in the halo and spark framework that inherits its layoutDirection from its parent. All others have layoutDirection of LTR.
      http://bugs.adobe.com/jira/browse/SDK-25995 - DateField opens drop down on wrong side when layoutDirection = rtl
      Added check if left edge of the dropDown exceeds the left screen bounds.
      QE notes: n/a
      Doc notes: n/a
      Bugs: SDK-25719, SDK-25995
      Reviewer: Kevin
      Tests run: checkintests, DateField
      Is noteworthy for integration: no
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/airframework/src/mx/core/Window.as
          flex/sdk/branches/4.x/frameworks/projects/airframework/src/mx/core/WindowedApplication.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/Button.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/DateField.as
