Revision: 15047
Revision: 15047
Author: klin@adobe.com
Date: 2010-03-25 17:40:30 -0700 (Thu, 25 Mar 2010)
Log Message:
Merge 15043 from 4.x to trunk.
Fix for http://bugs.adobe.com/jira/browse/SDK-25943. Embedded images were not mirroring even when the image component had an explicit layoutDirection set. The fix is to check if the contentHolder is an ILayoutDirectionElement when it is loaded and set the layoutDirection to null (inheriting).
QE notes: No
Doc notes: No
Bugs: SDK-25943
Reviewer: Jason
Tests run: checkintests
Is noteworthy for integration: No
Ticket Links:
Modified Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
Property Changed:
flex/sdk/trunk/
