0 Replies Latest reply on Mar 26, 2010 12:13 AM by Santanu Karar
    Trouble in with first column itemRenderer
    Santanu Karar Level 1
      I'm having an AdvancedDataGrid generated through actionscripts, but can not assign an itemRenderer specifically for the first column. Following are the generation code excerpts.
      var tmpColumnAC : ArrayCollection = aReportVO.showOrderAC; // Holds the properties to be created columns in the ADG
      var cols : Array = new Array();;
      var dgc : AdvancedDataGridColumn;
      advancedDG = new RowColorAdvancedDataGrid(); // Simple extended copy from ADG
      advancedDG.styleName = "shDataGrid";
      advancedDG.setStyle( "folderClosedIcon", null );
      advancedDG.setStyle( "folderOpenIcon", null );
      advancedDG.displayDisclosureIcon = false;
      for ( var i:String in tmpColumnAC ) {
                  var tmpDgcVO : DatagridColumnVO = tmpColumnAC[ i ];
                  dgc = new AdvancedDataGridColumn( tmpDgcVO.columnField );
                  dgc.width = tmpDgcVO.minWidth;
                  dgc.headerText = tmpDgcVO.columnName;
                  dgc.wordWrap = true;
                  dgc.headerWordWrap = true;
                  dgc.headerRenderer = new ClassFactory( ADGridHeaderRenderer );
                  if ( tmpDgcVO.isFirstColumn ) dgc.itemRenderer = new ClassFactory( SHRowSelection ); // SHRowSelection is a simple VBox component
                  cols.push( dgc );
      var tmpDP : HierarchicalData = new HierarchicalData( someArrayCollection );
      tmpDP.childrenField = "children";
      advancedDG.columns = cols;
      advancedDG.dataProvider = tmpDP;
      advancedDG.draggableColumns = false;
      advancedDG.percentHeight = 100;
      advancedDG.variableRowHeight = true;
      advancedDG.displayItemsExpanded = true;
      vbListHolder.addChild( advancedDG );
      Thanks..
      ASB
