6 Replies Latest reply on Mar 27, 2010 12:57 AM by ChrisPaduan
    Flash Builder 4 Error: 16
    jmgech
      I just updated to Flash Builder 4 and it no longers launches on my MacBook Pro (or Mac Pro) running Snow Leopard.
      I have completely uninstalled the previous versions (Flex Builder 3 and Flash Builder 4 Beta).
      When I start up the application, it crashes with a Configuration Error : Error: 16 telling me to uninsall and reinstall, which I did :-)
      Can anyone tell me what could be the issue?
      nz
        • 1. Re: Flash Builder 4 Error: 16
          shahinyan
          I've got exatly same problem on my Vista machine... Reinstall it, then install it back, no luck...
          • 2. Re: Flash Builder 4 Error: 16
            KncTrnl1
            same thing here on Win 7 64 bit. Called tech support and after 3 hrs on hold was told there was no phone support for this product.
            did a fresh install of windows installed only FB4 and CFB and got same. error is repeatable every time.
            after I get the error 16 both FB and CFB get stuck in endless accept license loop. and will not run.
            Lack of support is un Acceptable!!!!!!! for  $700 Software.
            Made them refund my $699 now waiting 10 days to get my money back.
            The Price for being good sheep and buying on day 1.
            • 3. Re: Flash Builder 4 Error: 16
              ChrisPaduan Level 1
              Hi there,
              Can you check the permissions on the directory
                  /Library/Application Support/Adobe/Adobe PCD/cache/
              and the file
                  /Library/Application Support/Adobe/Adobe PCD/cache/cache.db
              Also, are there any files in that directory that end with .journal?
              • 4. Re: Flash Builder 4 Error: 16
                ChrisPaduan Level 1
                Same question for the folks using Windows. The directory on Windows is
                C:\Program Files\Common Files\Adobe\Adobe PCD\cache
                for 32-bit Windows
                and
                C:\Program Files (x86)\Common Files\Adobe\Adobe PCD\cache
                for 64-bit Windows.
                • 5. Re: Flash Builder 4 Error: 16
                  jmgech Level 1
                  Thanks for the advice Chris,
                  I checked the file permissions and they were fine, so I removed the cache.db file. I then relaunched Flash Builder 4 and it then ran fine.
                  I had to reactivate Flash though, but other than that, all seems to back to normal :-)
                  Thanks!
                  nz
                  • 6. Re: Flash Builder 4 Error: 16
                    ChrisPaduan Level 1
                    Hi nz,
                    I wouldn't recommend deleting the cache.db file as it will also require you to re-enter the serial number for existing CS3 and CS4 apps, but I am glad it solved your problem.
