0 Replies Latest reply on Mar 26, 2010 6:44 AM by Keith_dk
    index entries disappear in chm output
    Keith_dk
      Product: TCS 1 (FM8 ver 0p277 + RH7 ver 7.03.001)
      All my text and index markers are created in FM and then imported into RH7. This works well, but the problem occurs when the FM index has a format similar to the following example:
      Commands: for standard users
      Commands: for super users
      where Commands is the top index marker, which doesn't have a link in its own right.
      Although the import is OK and the entries appear in the RH index list, the Commands entry has a cross-reference property. The problem occurs when the chm or html files are created. The Commands entry disappears and its sub-entries become sub-entries to the previous index top entry with a proper link.
      I have found a work around for this problem, to go thro' my RH index list and clear the Cross-reference check mark in the Index Keyword Properties box. Unfortunately, this is labour intensive.
      Does anyone have a solution? Is there some import setting that automatically does what I have to do manually?
